A friend of mine has just rung me,he is on holiday at Paington in his Swift 500? Challenger 2007?
The problem is that when he switches on the hot water it spurtles (technical term)for a couple of minutes and then settles,this is like when you first fill the system and get the air out.What happens then is if you use the hot again in say half an hour it happens again,it sounds like air getting into the tank but he cany find any water leaks.He has drained the system and refilled,but still the same,and he has checked all joints for tightness.
I think his system is microswitch taps and not pressure switch but to me it sounds like a problem with a non return valve,is there one somewhere.
Sorry not to be too clear but I have not seen the problem for myself,all suggestions welcome.
