Help Please
Apr 26, 2010
325
We Have a Bailey GT60/620-6 Inside there is 3 main interior lights dome shaped with a switch on for either one bulb or two bulbs
Could anybody tell me how you remove the light covers for cleaning.
As I do not want to force anything a break it. I had a look yesterday but not sure how it should be done
Regards
146
Hi John
We too have a Bailey Ranger GT60 and found that there was quite a bit of debris in the light fittings when they were new.
In order to remove the plastic dome I just carefully applied a bit of pressure at one side, where the dome meets the base, and where one of the integral lugs is positioned. Once one of these lugs was free then it was easy to remove the dome. In order to replace the dome you just have to reverse the procedure. Just be careful as I am sure these lugs could easily break off from the rest of the dome.
Catherine
40
If you look carefully round the circular edge where 'glass' meets rim you may be able to see three small marks - there are where the lugs are. Very gentle pressure into these marks with a small screwdrive blade should release that lug and the rest will follow.
