Will try to be as brief as possible.
Collected Sancerre at 4 pm today after Truma SE mover had been transferred from our other caravan(work carried out by dealer).
Dealer gave me a run through of van and mover...all worked fine.
He supplied me with a "adaptor lead" as my car has 7 pin electrics and Sancerre has 13pins.
Drove home perfectly and parked outside of drive.Disconnected car from caravan(after seperating the two ends of the 13pin plugs)
Had a problem re-connecting plugs so rang dealer and was informed that I had to use a 50p piece,and turn the pins 1/4 turn anti clockwise to engage the two ends(I hope the next thing i did hasnt messed things up).
It would not turn anti clockwise but it turned clockwise 1/4 turn very easily(thought that i may have been holding it the wrong way round and trying to turn it wrong way)
Anyway,connected the plug to the safety socket,switched on isolator,turned on remote,and moved the van back about 6 feet(enough to move my car out of the way)
Moved car and returned to the caravan to move it into my driveway.
Nothing!!!!!
Van stuck in road with the rollers firmly against the tyres and remote control not turning on.
Fitted a brand new set of batteries to remote...still nothing.
Disconnected the leisure battery for 10 minutes then tried again.
Still nothing.
Have read instructions and it appears that the handset and control unit are not synchronised with each other.
Handbook states to "Press the reset button on the control unit and hold down(led flashes slowly)and after 5 seconds,the led starts to flash rapidly"
Mine doesnt!!!!
As soon as i press the reset button,the red led starts to flash rapidly straight away for some reason.
It says "After successful synchronisation,the red led flashes rapidly"mine just flashes slowly after trying to synchronise.
One thing i have noticed is when i flick the on/off remote switch to "on"....i get just a "nanosecond" of green light.
Hope someone can help.....suppose to be going away on Friday and cant take time off work to return to dealer..
Nothing!!!!!
Still nothing.
Mine doesnt!!!!
