Help!!!!
Mar 23, 2021
46
12
1,535
Hi all,
My question concerns the slide out table that sits on the drawers under the front window on my 2016 Lunar cosmos (quasar). The upper table surface is mounted on fixings that allow the slight up and down movement that allows it to drop behind the lower slide out surface. I need these fixings, but it’s difficult to search for them as I don’t even know what to call them.
Any advice is appreciated.
Kind regards,
Mark.
1,586
6,935
Many caravans have these types of pull out tables. I bet all the mechanisms are the same.
If yours is missing, look at another van and see if you can get a manufacturer and/or part number.
1,539
Try breakers to see if they have the part. SFM are one of the biggest and they show photos so you can see if it is the right one. The Cosmos was a dealer special based on the Quasar which would be the part to look for, although I think all Lunars will have had the same fixing there.
