Please feel free to copy and paste and alter to your own needs.
LEAVING HOME
1. Connect to electric & switch fridge to mains to chill.
2. Flush water tanks with Milton (start of season only). Empty tanks if necessary.
3. Check everything stowed securely. All doors, rooflights & windows closed/clipped.
4. Switch fridge to 12 v setting & secure door etc. Control panel set to "Off".
5. LPG off and secure. Battery OK.
6. Mains cable disconnected from power first then caravan & then stowed.
7. Check all tyre pressures & wheel nuts (incl spare).
8. Remove wheel clamp & hitchlock. Switch on and wind on Motor Mover. Raise 4 corner steadies.
9. Handbrake fully released. Hitch up. Raise jockey wheel to highest & clamp. Attach breakaway cable & check stabiliser engaged. Connect 12 v cable & check all lights & mirrors ok.
10. Switch off and wind off Motor Mover. Stow towball cover & motor mover control.
11. Stow drill, levelling blocks, chocks & step. Lock door.
12. Check caravan level or slightly nose down. Car Level.
Stop after 20 miles to check all still ok, nothing moved, wheels cool, no cables trailing etc.
ARRIVAL ON SITE
1. Check in with site warden & reverse or drive onto pitch.
2. Disconnect breakaway cable & electrics. Unclamp & lower jockey wheel. Unhitch, disengage stabiliser. Apply handbrake.
3. Switch on and Wind on Motor Mover. Release handbrake. Move caravan into position.
4. Check levels with spirit level & adjust using ramps & jockey wheel. Move wheels till ok to fix wheel clamp. Apply handbrake. Lower corner steadies.
5. Switch off and wind off Motor Mover. Stow control safely.
6. Move car, put towball cover on, remove extending mirrors & check tyre pressures.
7. Connect mains cable to caravan first then to power.
8. Connect fresh & waste water containers. Fill and add chemicals to toilet tanks.
9. Control panel set to 'van'. Switch on pump. Purge water heater by running hot tap till running freely.
10. Connect/switch on LPG. Switch fridge to gas/mains. Switch on water heater gas/mains.
11. Apply hitchlock, wheel clamp and Hitch Head cover.
12. Assemble awning.
Put kettle on or open bottle of wine and relax.
LEAVING SITE
1. Awning down.
2. Disconnect water & waste hoses & empty tanks.
5. LPG off and secure. Battery OK. Control panel set to "Off".
6. Mains cable disconnected from power first then caravan and then stowed.
8. Remove wheel clamp & hitchlock. Switch on and wind on Motor Mover. Raise 4 corner steadies. Handbrake fully released.
9. Hitch up. Raise jockey wheel to highest & clamp. Attach breakaway cable & check stabiliser engaged.
10. Connect 12 v cable & check all lights & mirrors ok.
11. Switch off and wind off Motor Mover. Stow towball cover & motor mover control.
12. Stow drill, levelling blocks, chocks & step. Lock door. Check caravan level or slightly nose down. Car Level.
Adjust as required if you don't have a motor mover etc
