Hi it keeps giving me an error saying file is too big when i upload a photo?A photo would help unless a contributor has an identical van?
You should be able to insert a lower resolution file photo.Hi it keeps giving me an error saying file is too big when i upload a photo?
Details are in the thread title.It is not something I recognise. Can you tell us the caravans make, model and year as that might help.
My suspicion is that it is for the water pump, and the light shows when it is switched on and probably flashes when the pump is in use.
Hi its a 2005 abbey spectrum 540 both water pumps are controlled from the main panel and the gas locker light has a seperate switch on the a frame 👍🏻👍🏻It is not something I recognise. Can you tell us the caravans make, model and year as that might help.
Thanks but my awning light switch is lower down next too heater and water controls 👍Thinking laterally is it possibly for the awning light, especially if it has a PIR activation then the yellow LED would indicate it was active?
Thanks ill have a look and see what turns up 👍👍If no one can answer try this for the handbook. It will; probably be useful for other things s well. The handbooks cover all ranges for each year and are not model specific.
Download your caravan, motorhome or holiday home handbook
Read and download your owners and technical handbook for your Swift touring caravan, motorhome, lodge or holiday home.www.swiftgroup.co.uk
Thank youTry the link above in Raywood's post, you can select the technical or owners manuals having selected the date required, the latter has full wiring diagrams which may help identify the culprit! The owners manual is a generic swift option for the year but has many pages from Swift and from appliances manufacturers.
Good luck!
mmmm should i hear anything when i switch it on or is it temp sensitive thanksThe switch might be for cooling fan for fridge the yellow light shows that it is on .
Could be onto a winner then? Ive had a look at the diagrams that raywood posted but cant find switch lol i am meant to have some sort of remote control that turns the lights on etc anybody know where i could find one ? 👍😁Hi Paulyh75 i look at another forum and someone else has ask the same question about a 2005 Abbey Spectrum 540 about a switch just above the door dont know what it does and someone said what i have put back to you .
