I suspect the hitch damper on my van may need replacing. The caravan appears to brake hard when I brake the car and tends to thump into the back.
Testing the damper I can push the hitch in using both hands with arms braced back onto my legs. This is fairly easy. The hitch will also retract partly when given a good shove with a foot. Trying to get a bit more technical, I've used a luggage scale to pull back the hitch horizontally and it takes around 40 to 45lb to do this. The hitch resumes full extension within about 5 seconds when relaeased.
Can anyone comment on whether this sounds like a worn out damper. Unfortuneately i do not have access to another caravan to do a comparative test.
Assuming it is worn, is replacement straight forward ( reeasonably capable and plent of tools) and does it really require two sets of hands - perhaps to keep the damper compressed while it is fitted.
Advice appreciated.
Advice appreciated.
