Hitch movement
Nov 23, 2024
Hi, sorry if this is a stupid question but relatively new to this.
We've just got back home with the van having had warranty work done, some on the electric cable on the hitch. There was a bit more knocking than usual when towing home, mostly when turning although not always. The only thing I can see that's any different is there is a bit of play rocking left and right in the hitch, just a few degrees each way. Should there be any play on the hitch at all? I can't remember there being any before it went in for the work and previously there wasn't any knocking noises when towing, but I hadn't paid too much attention because there was no problem.
Thanks for any help.
3,532
1,364
If understanding the question correctly, the hitch , being coupled to a ball can pivot around the ball in every direction, within the limits the various stops allow. So with the pad setting handle up its top can rock to the left or right, quite a few degrees.
Any contamination on the four pads within the hitch, can cause the hitch to "groan" as the unit goes round turns. A good cleaning with "brake cleaner" can help stop this: I doubt the noise itself makes any real difference to the way the hitch performs.
Thanks for the reply, my description wasn't great but couldn't get my short video to upload.
The best way I can describe it is if you put your hand on the stabiliser and turn it in either direction the hitch rotates a few degrees each way. The hitch is as it would be if coupled to a ball as it has the hitch lock in place at at the moment.
It wasn't really a groan that we could hear but a definite knock. From your description it sounds like there should be some movement so I'll see how it is next time we take it out.
Thanks again.
3,532
1,364
Does Fig 2 HERE help?
[Acknowledging the excellent contributions of a past contributor to our caravanning forums]
Whilst it may not be exactly the hitch you have, the range are very similar, with little more than cosmetic differences in the heavier duty series.
This is not really "play", its the designed in articulation, here to accommodate the relative roll differences between the tow car and van reflecting undulations in the road.
Jul 15, 2008
3,748
842
......from your description and if you were able to hear a definite knock when turning, then I would be checking the towbar mounting bolts for tightness.
They have been known to loosen where the towbar frame is attached to the towcar.
Reactions: toad a caravan
