Hi Folks, can anyone advise i was looking to buy a hitchdrive mover. Our caravan is parked in our driveway, however it is on a hill and it is difficult to push it up the hill. Anyone help?
I've had a similar problem so I looked on the small ads and purchased a used Motormover ET. I had to purchase an adaptor so that it would fit the towhitch, as it normally replaces the jockey wheel when it's in use and thats ok provided your jockey wheel is on the outside of the A frame. However I find it excellent with low speed and good manouverability. Its not permanently fixed so I don't have to worry about it being taken. You could go for the type that fixes to the 'van and locks onto the wheels with remote operation which tend to be rather more expensive but do the same job. Only advantage is you can use it on some sites where there's a need to reverse in a tight area.
