Hello
I have an Adria Adora 613UT Thames, 2014, which we have had from new.
It is fitted with Truma Ultrastore Rapid GE water heater, with a Truma Ultraflow Compact Housing and a Whale pressure switch.
I have been having various problems with both the hot and cold water supply to all taps and shower over the last few months;
1. The system does not seem to have the pressure it used to, despite having adjusted the pressure switch many times.
2. The pressure in the system seems to fluctuate through the day.
3. When operating any cold tap, particularly first thing in the morning, hot water comes through first.
4. If I switch off the pump master switch before going to bed. There is a lot of air in the system, particularly the hot, which requires a good bleed to get things working.
Any advice very gratefully received.
Cheers
Phil & Lesley
Cheers
Phil & Lesley
