How much power do you need?
Nov 12, 2013
2,955
Make sure you understand what your power requirements are before heading off on tour, says Practical Motorhome's technical expert Diamond Dave. Find out more here.
Apr 3, 2017
29
Yes, as usual Dave is spot on in his article.
It may also be worth checking the fuse in the plug of the appliance being used. We have a 900w travel kettle which draws 3.9 amps and a matching 700w toaster drawing 3.04 amps, both have been fitted with 13 amp fuses rather than the required 5 amp suitable for the load. If either has a fault ideally users would prefer to replace a single appliance fuse rather than reset both the van and power source RCD which, as Dave points out, may also affect a neighbour.
Another handy note which may be worth labelling near to the habitation electrics:
6 amp = 1350w... 10 amp = 2250w.
Limiting yourself to these values will still leave a little in reserve giving peace of mind to the consumer.
