How to bleed the heating system on a cameo 500gl
Hi all iv just got a cameo 500 and the heating system gets very hot and I can hear the circulation pump runing but the pipes to the under seat heating just don't get warm how can I bleed it as I can't find anywhere
I assume this is an Alde system. You can download manuals at: http://www.alde.co.uk/manuals.php
Hope you can find yours there.
The symptoms as you correctly believe are classic of the heating circuit being "air-locked" and needing to be bled, or force purged.
I can't help you in directing you to where all the bleeder points are with this van; my Hymer has 5, each on a tee rubber coupling tube joining the rad's to the pipework. These were very hidden and required me tracing the tubes all round the van and dismantling bits of furniture. A torch and hand held mirror helped in the blind areas.
How old is your van? Modern vans have the bleed point raised to make them more accessible, but earlier ones are at radiator level, so you have to get under bunks at floor level
