Hi,
I have a Gunson automatic 12v battery charger allegedly suitable for use on all 12v batteries including leisure batteries. It's not new I've had it a good few years. The question is how do I check if it is working as I have a feeling it has given up the ghost on me.
Connect to battery, set to auto on and 100% charge as per instructions and as I've always done, the needle on the guage doesn't even flicker. It should, and used to, rise to even quarter or half way up the dial, between 3 and 5 then quickly fall back towards zero depending on how much of a charge the battery needed. Changed the fuse in the plug and that is about the extent of my knowledge with chargers.
Should I be able to get a reading with a multimeter from the charger connections when off the battery? Battery reading 12.6 before going on charger, same reading when on the charger.
Shopping for a new charger over the weekend is it? and if so what do you recommend?
I've seen some recommendations for the model from either Aldi or Lidl but you never know when they are going to be available.
Robert
Robert
