Hi All the first of probably many posts on my restoration project .
Its a 1983 Cosalt Clubman 414 . It would appear to be built on an ALKO chassis as when I removed the wheel trims the ALKO legend is on the hub cover .
The manufacturer plate for the van has a max gross weight of 829kg on it but I cannot see any other plates but would not know where to look..
Is there a way of telling which chassis it is or were they all the same ?
The tyres fitted on the van are 155x13 but the spare is 165x13 which is likely to be correct?
I will replace all tyres once we are ready for the road as a safety measure on age alone.
I have assumed that if the max gross weight is 829 kg then on a twin axle this is approx 415 kg per tyre plus 10% factor of safety suggests an 82 load rated tyre (475kg) is sufficient is this correct or is it better to go up to say a 90 rated 8 ply tyre or does this affect the way the outfit rides?
What does this max gross weight mean exactly?
Is this the type of chassis that needs the "One shot nuts" I have read about for the hubs?
Are other parts such as bearings and brake shoes a standard type?
Are there other items that should be replaced , the chassis is not seized up, the hubs are free and the handbrake works on and off the brakes are untested so far as I need to get my tow bar fitted first ..
If it is an ALKO chassis I understand it was galvanised from the factory so should I just pressure wash it off or wire brush it or will this damage the galvanising ?
Is it advisable or even possible to replace the hitch with an anti snake type of the ALKO type I realise the van is lighter than most modern vans but would it make it easier for a novice to tow?
