My last Swift included one standard 6 kg steel gas cylinder, the spare wheel, EHU lead, water pump hose, no fluids, caravan documents, and the step In MIRO. The maker can advise or it may be in the handbook.Are gas bottles included in MIRO? I didn't think they were, certainly not with Bailey, neither is the standard fit solar panel nor I think ( may be wrong) is the spare wheel. For their MIRO Bailey specify that all water containers and the toilet must be empty - the fluid allowance that the NCC suggest is taken by the fluid in the central heating system! The only other things Bailey include in the MIRO AFAIK is the step, the EHU cable, and the winding handles.
Gas bottles have been included in the MIRO since about 2011. On our caravan the gas allowance is 20kg. EHU cable is included in MIRO along with spare wheel. As we have an onboard tank the waste master is included in the MIRO. Our battery is also included in MIRO due to E&P system. Solar panel is also within MIRO.Are gas bottles included in MIRO? I didn't think they were, certainly not with Bailey, neither is the standard fit solar panel nor I think ( may be wrong) is the spare wheel. For their MIRO Bailey specify that all water containers and the toilet must be empty - the fluid allowance that the NCC suggest is taken by the fluid in the central heating system! The only other things Bailey include in the MIRO AFAIK is the step, the EHU cable, and the winding handles.
Spot on, but we know who has facilitated this confusion and I suspect the savvier quite accurately can work out why.Woodentops comment is classic example of why you cannot assume anything.
There is no EU directive defining what is and what is not in the MIRO. It’s an industry standard, BS EN 1645-2:2008, and even that is open to a certain amount of interpretation by the respective manufacturer. The only reliable way of establishing your starting point is to weigh the caravan empty.The UK's NCC, by directly avoiding and corrupting the application of the EU's directive aimed at clearly defining what is and is not in the MIRO.
