Although a Lunar related issue, this is a general question on wording in a book. This is from the 2011 Lunar owner's handbook Page 50
Int/Ext switch When in the internal position the internal pump fitted in the underfloor water tanks is operational. If the water level falls to a pre-determined level it will automatically switch to the external pump until the underfloor water tank level rises.
When in the external position the external pump will be operational and will automatically fill the underfloor water tank. LEDS are situated adjacent to the switch indicating which pump is activated.
The above indicates to me if the water level in the underfloor tank drops to below the pre-determined level, the external pump will top up the underfloor tank to the predetermined level. Dealer is stating that you have to manually switch the pump to external pump for this to happen. We disagree.
The above is one of our issues. The other is when for example you are on external pump and the barrel runs out of water and you switch to the internal supply. Although you switch to internal, the external pump continues to run. Lunar via their design team, electrician etc state that when you switch from the ext pump to internal and the internal tank is full, the external pump should switch off. I have several emails from Lunar that indicate this, but dealer states Lunar is wrong.
We are caught in a Catch 22 situation. With regards to the 1st issue, how do you interpret what the owner's manual states?
