Hymer Nova 530 Heating System
Apr 7, 2008
4,909
Hi, i have just bought a Hymer Nova 530tb, ( 2001 ) and am waiting for it to be serviced, in the meantime does any body know if the heating is gas and electric, or just gas ?? as i cant get the gas to work for the heating and cant seem to find any other switches...Steve
3,538
1,364
The UK build spec ones were both Gas and mains Electric heating. Continental will depend on original order spec where electric was generally a costed option.
There should be a gas isolation tap directly under the sink, one of a group. Hymer say these should be turned off for each trip, maybe the previous owner actually did this!
Also if everything else fails replace the igniter battery.[pull off heater housing from the top, battery box on the base plate left side; it has a slide up cover . battery one AA ]
Cheers John
Apr 7, 2008
4,909
Hi JTQ
I have put new batteries in and re read the hand book, it says that you should be able to hear a audible clicking sound...nothing at all....wonder if the automatic lighter is up the creak ?..... Steve
3,538
1,364
Hi JTQ
Steve, with my degenerated hearing any click must be very quiet, however whilst its "clicking" it also flashes the red indicator light ,top surface far left.
Battery the correct way round? Positive on mine is to the left.
I would also check that the wires from the igniter are in place.
Apr 7, 2008
4,909
i have had the front cover off so that i can see the viewing window on the bottom left, were abouts is this red indicator light ??? batterys are new and checked with a multimeter, as to the way round i put them in as the marks in the plastic were + & - .... do you think i ought to swap them round ??
Steve
Apr 7, 2008
4,909
Steve
Apr 7, 2008
4,909
Steve
3,538
1,364
Steve, The heater in my 2002 545 is a Truma S55T.
The indicator light is on the top cover plastic piece upper surface far left side, about 8-10 mm dia. It flashes whilst pressing down the gas control/ thermostat knob that is on the right upper surface. When the gas is lit you hold the knob down for about 10 seconds to ensure the flame failure valve is set and on releasing the knob the light goes out.
No don't put the battery in the "wrong" way round, as you say its marked then that's the way it should go.
I will see if I can find a link to the manual and post that.
Apr 7, 2008
4,909
Hi JTQ
iv just been up to Lowdham's and spoke to there spares department genius who assured me that it was my spark unit what was not working, i purchased a new one put it on and yes you can here it spark, and now iv got my heating working, i also found out how to check if it had 240v electric heating in...mine has not got it...no problem there..
Many thanks for your advice
Steve.
ps. this gets you all the drawings up for Truma @ Truma UK
http://www.leisure-supplies.co.uk/truma/heating_schematics/
