I'm new and i'm missing some bits
Aug 14, 2013
53
Hi
Just wondering if you can help me. Whats that thing called on the left thats missing the door?
Reason i ask is i need a new one with door and all the bit that attach to it. I know it's something to do with the water but thats about as much as i know. Thanks!!!
Aug 14, 2013
53
Also please could you tell me what this switch in the top middle is called? (the one with the red light)
Thanks again
Apr 20, 2009
5,640
1,047
Could this be what you are looking for click here
looks like it could have been superceded
Take a look at the 2nd from left in the photo, click to enlarge the photo
Not saying it is the right one but will give you an idea
Hope it helps.
937
The part with the missing cover is the water inlet housing.
That type has been replaced by the Truma Ultraflow system.
The second item you ask abiut is the mains switch for the cascade water heaterfor when being used on electric as the fuel source.
4,335
Hello oBladeo,
I think Damian has covered the parts and functions, but I note that the water heater is not actually fitted to the caravan.
You should be made aware that for you and your families safety all gas fitting and electrics should be carried out and tested by a competent fitter.
Aug 14, 2013
53
Hi thanks everyone for the feedback
I have now bought the cascade 2 whole system as someone had gutted mine and not included the part in the sale. Also the caver crystal replacement water inlet housing and filter is also on its way.
Thanks allot for the help I will be posting more help I require sorry!!!
Found out my van has about 1/4 rot on one side so will post for advise on removing the caravan side tonight.
Thanks again!!!
Apr 20, 2009
5,640
1,047
Thanks again!!!
oBladeo take a look here Damp Repair
It was aproject I did on my last van and may give you an idea of the heartache you are about to encounter
40
Your photo shows a collection of bits and wiring that really do not look too wonderful. Unless you are comfortable with your abillity to get this lot tidied up I seriously suggest you got to an Approved Workshop or otherwise qualifeid person.
Very sorry to be a wet blanket but I'm concerned for your safety.
Aug 14, 2013
53
The pictures i've used are from ebay as i didn't have time to run down and take my own.
Don't worry my van is allot cleaner than that mess.
The great thing about caravans are they are so simple to fix it's just getting my head around what things are called.
Aug 14, 2013
53
Well i fitted a carver 2 last week just need to hook up the 230v socket but i've tested it in 12v and gas and works perfect. While there i also fitted a new filter and filter housing as the old one was shocking. I'll be cleaning the van once i have finished the repair work as i'm resealing the whole van. Once the van has been finished i'll have someone to gas safty check the whole lot.
Aug 4, 2004
4,343
It may be an idea for peace of mind to get the electrics checked also. It shouldn't cost very much to get certification.
