Where can we find information on caravan towing for the 1st time, Also a owners hand book for abbey vogue216 1997?? Many thanks in advance
Try having a look at the Caravan Motorhome Club site. They have lots of technical help sheets. Is there anything specific as your question is very open ended?Where can we find information on caravan towing for the 1st time, Also a owners hand book for abbey vogue216 1997?? Many thanks in advance
Don’t know your van but…Thanks to you both, We were wondering if there is a user mannual for caravan? which explains what is where how to use for example the fridge, seems to be gas/electric??
I thankyouI highly recommend doing a couse. It made me a lot more confident going out for the first time and instilled good practices in me.
will try halfords for a hard copyGerry, Haynes do a nice little handbook about caravanning, from Halfords or online,
Thanks will doThis Practical Caravan website contains a wealth of information about all aspects of touring caravan ownership, but unfortunately it can be difficult to access for a novice forum user.
Navigate to the website Home Page.
Use the 3 horizontal bars ( top left) to access the Advice page.
Click on the text breadcrumb to navigate to Towing, then scroll down and there's some very good advice from Towcar Editor David Motton.
It's a bit of a faff, but unlike a Haynes manual the advice from the website here is free.
I used our bathroom scales very successfully to “ calibrate “ a noseweight gauge. Once done i did not need to bother again until I changed tow car and the noseweight of the car changed. The bathroom scales are very accurate as evidenced recently when my family went to Greece and their cases maximum was 23 kg and I weighed them when holding them circa 122.5 kg, and just under 23 kg when checked in. I used the same approach when weighing everything that went into or on the caravan which was then entered into a spreadsheet fir different loading scenarios. IE long summer weekend, two weeks in Norfolk in January.Parksy We have found out that the nose weight for our Suzi Grand vitara is 75kg,rather than use the Bathroom scale method will get "the proper tool" for the job.
They can be tricky to put on and unless they are a good fit, covers can potentially damage caravan paintwork.Food for thought parksy ,What is your view on over winter covers for caravans?
I found the noseweight gauge more convenient once I had “ calibrated “ it against bathroom scales as it could then be taken in the van for checks on noseweight prior to travelling home especially when abroad or after draining the beer and wine cellar 🍷😂The 75kg value you have found for your car is a weight limit not a target. If you don't already know, the actual nose load a trailer produces is dependant on how the trailer is loaded, You have to trim the noseload by either moving the load around inside the caravan or adding or removing items bearing in mind you must not exceed the caravns MTPLM.
Proprietry nose load gauges are simple and not entirely accurate. Some are hopelessly inconsistent with the values they read. The bathroom scales method is usally more precise and consistent. I wold not bother with spending money of a proprietry gauge when you don't need to.
Our bathroom scales are within 1.0 kg when I use them to weigh airline checked luggage up to 23kg. That’s when I hold them on the scales then stand on the scales without the suitcase and deduct my weight from the total of myself plus suitcase.Buckmans correct, how accurate are bathroom scales, I am happy with a + or - 2 kg, once you know your caravan, you know how it tows, on the way home I know I might be 3 kgs lighter on the noseweight due to gas usage, fridge is right over the axle, so not worried about it, toilet at the back, Same as the way out. Everything else is the same.
