Interior help!
Apr 9, 2010
Hi
We have a Sprite Super 450eb and whilst touring this weekend we suffered a blowout on the passenger side.
The blowout caused internal and external damage.
We have managed to fix the majority of it however it has damaged the interior panels of the cupboards at the bottom.
Does anyone know where we could get replacement panels from or an alternative that would hide the damage (ie mdf covered??)
Apr 15, 2010
96
for a cheap repair,get 3 mm ply from diy shop,coat on p v a glue to seal then cover with matching paper or a vinyl covering to match interior use a bathroom wallpaper paste as well or it will peel of.at all times the side wall strength must be maintained so if damage is bad insulation will need replacing and glued in place,be careful not to pierce outer skin aluminum panels as only mm thick.the vans strength is in its bonded panels,wallboard is very expensive new about 1 grand a piece from a dealer try scrap yards dealers who supply end of lines,but you will have to collect.hard to give advice as i can not see damage but hope this helps .
