internal alarm bailey unicorn
Aug 29, 2016
Hello we have a Pamplona and it has a internal alarm sounding , any ideas what it is? Can hear it louder coming from fuse box under the seat but no idea how to stop it or why it's activated any advice will be appreciated
1,819
Not sure how old yours is or if this is the problem but some of the early ones did have a problem with the alarm going off when it should not. The problem was supposed to be due to the frequency used to set the alarm., They needed more different ones than were used which meant a Unicorn near to you might have an alarm on the same frequency and could set off your alarm when setting theirs. I think they could also disarm yours when doing theirs.
Not sure if there was a cure for this though, if that is your problem, but a Bailey dealer might know if no one else on here can help.
2,260
Our unicorn Valencia doesn't have an alarm. You haven't left a smoke detector or co2 detector or a child's toy underneath a seat box have you. No offence intended: it's the sort of thing we would do!
Hi Mel, no nothing like that been told it's the mover???? But weird how our fridge has defrosted with no warning it's all lit up as if should be but it's warm grrrr
937
The mover does not have an alarm , it is connected directly to the leisure battery and does not use any of the van wiring.
As for the fridge the internal light and control panel are supplied constantly by the leisure battery but that does not mean the fridge is cooling.
