Internal partition removal
Feb 27, 2019
I am thinking about removing the lateral partition that separates the rear bathroom from the rest of the caravan... and then removing the toilet.
I am concerned though that the partition, however flimsy, is in some way structural and integral to the rigidity of the van.
The van is a 2003 compass corona 524.
Thoughts?
Many thanks...
3,949
Most caravans need some of the internal fittings to provide structural strength. I would suggest you get a mobile caravan engineer to look at what you are proposing.
8,151
The toilet is probably the most rigid item in the caravan as it has to bear considerable loads at times :woohoo:
1,818
I agree with the Prof. Get some expert advice. My feeling is it could be part of the structure but not knowing the exact model I cannot say.
Not sure why you would do this but I do wonder if turning it into an archway might be a better bet as it should maintain the rigidity if it is needed.
