Internet Issues
Apr 20, 2023
26
Hi everyone.
Currently using a TP Link MR6400 mounted inside my wobbly box and a Poynting omni-directional antenna mounted on the roof just above the door.
The signal inside the van is "acceptable" but outside in the awning, the signal is "dire" to say the least.
Where am I going wrong? and how can I get an improvement in the signal received outside.
The MR 6400 is supposed to be good but I have only "plug and played", no set-up as such. Is this my problem?
Thanks in advance.
Nov 30, 2022
1,223
1,038
1,435
Possibly because your caravan body is blocking the signal from the TP link Especially if your caravan has an aluminium skin. When inside the signal doesn't have to find its way out through the bodywork.
Just a thought
Sep 29, 2016
1,816
235
I suspect that Mr Plodd is correct, your antenna is unlikely to be the problem.
Try connecting your PC\laptop\tablet or whatever to the TP link using an etherenet LAN cable having RJ45 connectors.
e..g.
