We have a 2003 Swift Celeste (which is a dealer special based on the Charisma) - we have just returned from holiday and for the first time have had trouble with a leaking kitchen sink tap. It is a slim cylindrical type that swivels down into a recess in the sink top so that you can lower the glass top over the whole sink and draining board. The tap is operated by a separate 'paddle' type lever set slightly behind the tap.
The leak - which happens whether the tap is actually in use or not - seems to come from the join in the tap that enables the swivel action ie it is about 1 inch from the base of the tap.
Does anyone know if this is a DIY job? Might it just be a washer, and if so, is it possible to dismantle the tap to replace it?
If we need a whole new tap unit, how would you take the old one out? It seems to be completely sealed around the base to the actual sink unit and we wouldn't want to scratch the sink by trying to prize it out.
Thanks for any advice anyone can give.
