Left Indicators
Sep 29, 2008
36
18,530
Please help if possible i have tried alot of things but my left indicators on my caravan do not work when connected up - on two friends cars the indicators on the van works {my car also powers there caravan ok} i have changed both car and caravan plugs with top quality plugs - checked all fuses - the audible sound sounds that the caravan is connected and working but no flashing - have checked and changed both back and side indicator bulbs with no success - the caravan centre found no problem there end and the car garage found all ok there end i am so lost as to what to do bar buy a tent!!!!......Please help.
Dec 14, 2009
111
Have you tried cleaning earth wire on car were it connects to body / try your car on another trailer etc . if dont work on another trailer it can only be a fault on the car side check all the scotch locks etc hope that helps a little
regards peter
Jan 21, 2007
18
regards peter
Hi Peter, i had a very similar problem to you,the audible sound was saying indicaters were working when they were'nt, but auto electrician changed it and problem was solved. hope this helps,
Graham...
Jun 29, 2010
regards peter
Trailer light problems such as brake or tail lights flashing instead of the winkers are almost always down to a bad earth. the current just finds another way out - ie via the stop or tail bulbs.
Refusal to come on at all is a dud bulb, blown fuse, dodgy socket or connector. Check for continuity with an ohm meter from the trailer earth terminal to the L&R winker terminals - if continuity OK then supply to those terminals from the car must be suspect - Connect a Voltmeter across the earth and winker feed terminals with the winker switch 'on' (I generally use the hazard flasher which checks both bulbs/terminals together.)
Good Luck - Beano.
