left side idicaters not working
Nov 3, 2008
elldis hurricane gtx has title says. they was working took them apart to clean up has some times had to twist the bulb to get them on . now i have put everything back together they did not work on the left side.all have been put back together correctly no joy. i undone the black plug off the van 7 pin black, the blue wire was not connected . i reconnected it still no joy could i have blown a fuse some where or are all the indicators on 1 fuse thanks for any help
Mar 9, 2006
265
The blue wire is actually for your fog light.The L.H.Indicators are on the yellow wire (pin 1). It's very possible that you have acidentally blown a fuse. On my 'van,(Swift), from memory, the left and right indicators are fused separately, and the fuse panel is on the front bulkhead underneath one of the seats.
Nov 3, 2008
thanks for your reply thats what i needed to no if they had there own fuse seperete will check tomoz thanks again
Nov 3, 2008
thanks again for your help tried all sorts no joy, took the car to my mates hooked it up to his trailer found out its the car not the caravan thanks
