how do i go about lighting up the road lights without the caravan being connected up to the car.I have a bailey pageant bourdeux, thanks
thanks bill i will try this ,the reason is that my caravan is towbar first in my drive and i would like a piece of kit that would show you at first sight which lights are working before the van is connected up to the car on the roadI would wire up a socket (7 0r 13 pin as appropriate) identifying the pins required for the road lights and plug in your van plug You will still need a 12v source of course, if not the car a separate battery. As a matter of interest why do you need to do this? (if it is to test the lights but manouvering the car into position is too much hassle as I once found in the past, then do as outlined above but you need a long enough lead to reach the car and fitted with a plug to go into your car socket) I realise this will not be too easy if your van is in the next town to where the van is parked!!
Bill D.
Yes, good idea. I made mine after I had a problem with the electrics when we were all hitched up ready to go, delayed us by several hours when with the extension lead I could have found out we had a problem the day before.thanks bill i will try this ,the reason is that my caravan is towbar first in my drive and i would like a piece of kit that would show you at first sight which lights are working before the van is connected up to the car on the road
