We had one and using it was brilliant. Make life easy fitting both locks onto the wheels plus making levelling easier.What are the thoughts on the Lock n Level for a twin Axle
Wouldn't be without ours.What are the thoughts on the Lock n Level for a twin Axle
We use a lock n level on our seasonal caravan it certainly made it level on the hardstanding pitch great itemWouldn't be without ours.
Best caravan accessory we've ever bought , well at least equal to the mover.
Maybe but it certainly saves a lot of hassle if you have a twin axle. I don't really seem any need on a single axle as you can use a ramp and easy to fit wheel lock.Seems a bit expensive to me even for a single axle.
Thats what I do with my SA Buckman and never having had a TA I cant really commentMaybe but it certainly saves a lot of hassle if you have a twin axle. I don't really seem any need on a single axle as you can use a ramp and easy to fit wheel lock.
I use a L&L on a single axle... The ramp solution is far more complicated, and a real PITA. All you have to do with the L&L is run back over it and stop where the lock aligns. Then pump the L&L! Having struggled multiple times with ramps I couldn't believe that people believe they are a realistic solution!Maybe but it certainly saves a lot of hassle if you have a twin axle. I don't really seem any need on a single axle as you can use a ramp and easy to fit wheel lock.
