low water pressure
Oct 7, 2006
54
hi
I have a 2005 unit fitted with truma crystal water pump and truma heater. I have had a few problems with the water system, but have established that the pump itself is OK, and I have replaced the housing unit, which removed the fact the water didn't work at all some times.
However, I consider that I have low water pressure (certainly lower than on my previous caravan which had the same system). can anyone offer an idea why this might be?
I have checked the polarity on the 12 volts,and it is OK
thanks
Steve
Jan 12, 2007
263
hi steve
have a look around on this site im sure that your problem has come up before and i think the fault was a kinked pipe in the system
hgv dave
Jun 11, 2012
1,525
28
19,685
Steve a good place to start is the little filters in the end of your taps ,unscrew these and check to see if they are clogged up with black like sediment.
I have a similar problem with our our Ace Supreme cleaned taps out as suggested here and there was improvement.
Good luck
Sir Roger
Oct 7, 2006
54
thanks all, I did spot another thread on this subject and had a read, and it gave me a few things to check.
I have found that by bridging across the wires supplying 12 volt to the tap I get a significant increase in pressure coming out. Does this mean the tap is worn or defective? and if so, is it repairable or is a replacement tap the only option?
steve
Oct 7, 2006
54
I have stripped the taps down and removed the micro switch, and have ordered a new one. I'll let you know if it cures the problem or not, just in case anyone has similar problems
Steve
