Aug 3, 2025
Hi all,
Hoping for some advice - while out on my last trip my indicator failed on my drivers side.
It was working when I checked it prior to leaving and I cant think of anything like a strong bump or anything similar occurred, but at some point in y journey its stopped working.
I've done the obvious thing of checking the bulb - which is in working order but what else do people recommend looking at?
Thanks in advance
8,921
Hi all,
Thanks in advance
Did you clean out the bulb holder and check local wiring connections for fastness.
Jul 15, 2008
3,886
1,063
......should be a fuse on the fuse board for caravan road lighting usually located inside the caravan on the front bulkhead under seating.
There maybe a fault in the caravan's road lighting plug such as a loose terminal and or wire.
