- Mar 14, 2005
- 4
- 0
- 0
Has any one experience of towing with both the above vehicles, how do they compare both towing and solo.
Sorry Mac, but you are wrong regarding the ACE (Active Corner Enhancement).This is an option or a standard fit depending on the model. My TD5 has self-levelling air suspension but NOT ACE.I'm on my second Disco TD5 and find it a great tow vehicle and superb to drive solo. I've had both 'chipped'and this really improves the performance. Pulls like a train !!
If Disco has air suspension then you must have the correct tow bar fitted for stability when towing, as the tow ball height will not sink, as with rear springs, when hooked up to the caravan. I've seen many a Disco with the tow ball height far too high. The Land Rover tow bar has an adjustable plate for setting the correct height & there is a different tow bar for vehicles fitted with rear springs. Also be carefull if 'Active Conering Enhancement' (ACE) is fitted - standard with air suspension - as this will mask any stability problems and you will not feel any warnings if stability is compromised. Having said that I have towed a big twin axle to France / Spain several times now with no problems.
