Microswitches Yuri
1,864
6,935
Do you mean replacing the micro switch with a manual switch. Then no. It would work but sounds cumbersome.
It would be possible to add a pressure switch and surge regulator instead of pressure switches, perhaps that is what you mean.
251
92
4,735
Has anyone used switch method instead of replacing the tap micro switch?
I presume that you have a external pump rather than a internal pump, to install a pressure switch would be reasonably easy however if your existing setup is ok why fix it?
