Minor bodywork damage
May 9, 2009
Hi, I have grazed the rear of my Sterling Eccles Topaz causing a scrape to the GRP/ABS plastic panel. It is on the lower corner and the damaged area measures approx 2 x 2 inches and is at a maximum of 3 mm deep. Can anyone recommend a product, such as a plastic gel filler which be suitable for a DIY repair...?
Many Thanks
Mar 10, 2009
86
you say its a maximum of 3mm deep, i would try so rub as much of the scrapes away with wet and dry and then t cut, i would avoid filling, you will be surprised how much will disappear
Mar 10, 2009
86
hi paul again, has the scrape gone through the gel coat or the plastic can you see a hole on the other side, if you can get to the back you could strengthen it, but i dont think it sounds that bad try my first suggestion and see what it looks like
