FEW!!!! My 2004 Shogun has passed it's MOT on 117k miles with no advisories. Really glad not to be facing more bills at the moment.
We wish we kept our Shogun now, always went through like yours with no problems,FEW!!!! My 2004 Shogun has passed it's MOT on 117k miles with no advisories. Really glad not to be facing more bills at the moment.
Not a bad price in all, but surprised some of the major defects were not shown as advisories at its last MoT.We wish we kept our Shogun now, always went through like yours with no problems,
Not so with the KIA last week, which was the first MOT we put it through
Repair immediately (major defects):
Monitor and repair if necessary (advisories):
- Nearside Rear Brake pipe excessively corroded (1.1.11 (c))
- Offside Front Suspension arm ball joint excessively worn (5.3.4 (a) (i))
- Nearside Front Upper Anti-roll bar linkage ball joint dust cover no longer prevents the ingress of dirt (5.3.4 (b) (ii)
Had all that done with a full service £735.00
- Nearside Front Brake disc worn, pitted or scored, but not seriously weakened (1.1.14 (a) (ii))
- Offside Front Brake disc worn, pitted or scored, but not seriously weakened (1.1.14 (a) (ii))
which wasnt bad really for what we had done but still did not expect it!!
Our 1996 Corolla also passed its MOT last week on 117k with no advisories. Pleased with it, but sadly we will need to look at selling or trading it in the near future.FEW!!!! My 2004 Shogun has passed it's MOT on 117k miles with no advisories. Really glad not to be facing more bills at the moment.
Great news well doneFEW!!!! My 2004 Shogun has passed it's MOT on 117k miles with no advisories. Really glad not to be facing more bills at the moment.
Is there a problem with trailers? Do the statistics show them as a disproportionate cause of accidents?My Santa Fe goes in next wednesday for it's MOT, 82k miles. Fingers crossed all will be Ok.
Is it time that trailers in the UK should have some time of an an annual or Biannual "MOT" similar to some countries in Europe.
I posted the HoC committee report recently on trailer accidents. The conclusions were that to bring in some form of registration plus testing showed a negative cost benefit. Accidents re caravans where mechanical failure was a cause were statistically insignificant. Majority, and again low incidence rate, were tyres, driver error ir other road user. So absolutely no basis at all for registration and/or testing.My Santa Fe goes in next wednesday for it's MOT, 82k miles. Fingers crossed all will be Ok.
Good result enjoyMy Little Insignia ( I say little, as some of the motors above dwarf it) MY13 85000miles sailed through on the 9th Aug., with no advisories.
I do the same pick the middle bracket from euro ,keep away from the cheap end and sometime get the high end depending on the job in hand.******, the SantaFe, failed on Off side Trackrod end joint. Bought a new one today and fitted it, £55 from Euro spares. Back to local MOT, for retest, all good. Now retracking , another £70.
Local auto factors sell the similar track rod end at £15. Sorry my engineering mind says I will go with the more expensive one. Probably better quality.
81k on the failed unit.
They’re cast iron!👍👍FEW!!!! My 2004 Shogun has passed it's MOT on 117k miles with no advisories. Really glad not to be facing more bills at the moment.
Kev mine had Major play, realy bad, ( no fault in the driving though) everything else was fine, luckily I know the lads in the garage and they let me under the ramps to check any faults.Just checked and the only one shown was
Offside Front Suspension arm ball joint has slight play (5.3.4 (a) (i))
Oh well all done for another year.
Can't go into details but sadly my job is coming to an unexpected end. Im sure I'll find something else before too long, but so relieved that the old Shoggy has made it through again. Yes it's not thev very best on fuel.... But without tempting fate it hasn't let us down t yet, so a fair offset. Seems like a few of us are going through Mot's atm.They’re cast iron!👍👍
We still have our blue P reg Corolla so we are probably not the neighbours. LOL!Our lovely neighbours had a P reg corolla, really nice blue colour - . guessing the same model. - Exchanged up for a newer i30- again nice car but they prefered the Toyota.
Didn’t you have something earlier that affected the rear end and tow bar location?Well the front wheel tracking didn't go quite as planned. Front needed adjustment by 1.5 degrees as suspected. But the rear wheel camber and toe was also out. Probaly since new. So got it all in line to really good specs. Outcome £130 but it dos feel a lot nicer.
A printed right out of the before and after adjustments.
All done nicely at Kwik fit in Bletchly. Bucks.
I did on the car at first, the only problem I have had with the towbar was the original one a Witter, as Original fitment would drop, on the cross bar, due to only having two attachment bolts on either side, both low tolerence fits, also with the Witter it was About an inch further from the center of the axle to the center of the Towball than recommended by Hyundai.Didn’t you have something earlier that affected the rear end and tow bar location?
Looking at the Kwikfit print out, very marginal rear wheel tracking and camber, it is probably set from new, and settling of chassie after 82k miles. But for the sake of £60, I prefer to get it all in alighnment. , with the front wheel alighnment as well.Didn’t you have something earlier that affected the rear end and tow bar location?
Thanks for reminding me to take car to fitters on Monday to check alignment.Looking at the Kwikfit print out, very marginal rear wheel tracking and camber, it is probably set from new, and settling of chassie after 82k miles. But for the sake of £60, I prefer to get it all in alighnment. , with the front wheel alighnment as well.
Hutch that was the previous years advisories, this years was as yours excessive play!!! Was replaced.Kev mine had Major play, realy bad, ( no fault in the driving though) everything else was fine, luckily I know the lads in the garage and they let me under the ramps to check any faults.
