motor mover for Eriba
Mar 13, 2008
Has anyone had an onboard motor mover fitted to an Eriba Caravan.As there is no conventional chassis on the Eriba(2001)are there ways of getting round this. Albert D
Jul 15, 2005
2,175
Albert,
The Reich Comfort is the recommended mover for an Eriba - Reich make dedicated brackets for the custom AL-KO chassis used on an Eriba.
Using these mounts, the motors actually fit much closer to the caravan floor than on a traditional AL-KO chassis. So ground clearance, etc., is very, very good.
As far as I know, no other company makes the necessary brackets.
And there's no real need to upgrade the battery above the standard 65AH fitment. It's perfectly adequate to manoeuvre the Eriba...
And you may want to look at the two UK Eriba web-sites - www.eriba-amiga.co.uk and www.eribaforum.co.uk
Robert (Eriba Triton 410)
Mar 13, 2008
Albert,
from Albert D
Thanks Robert for your help. The plates you mention seem to be welded to the "chassis"from info we have gained when speaking to suppliers and puts the cost to
Jul 15, 2005
2,175
Hi Albert,
No, the plates are bolted in place - and over on the Eriba forum people are reporting prices (just) under
