Feb 12, 2008
79
please can anyone help the motor mover grip wheel keeps slipping on the tyre, the model is a trauma mk2 with the what looks like stuck on grit on a roller, the problem is when it get the smallest amount of muck on tyre it slips, hence no grip the wheel when disengaged is 20mm which it states in the book can you get new type rollers which look like alloy or any other remedy thanks?
Check that the grit isn't worn away or peeling off if ok and the mover isn't too difficult to engage onto the tyres then you could move the unit nearer the tyres a fraction but mover should work ok if gaps are correct and rollers in good condition.
I'm pretty sure that i fitted a set of the new aluminium rollers in place of the old grit type but would check adjustment first as rollers ain't cheap.
Mike.
