MRO vs Gross Train Weight, Someone put me Straight
Oct 14, 2016
Complete caravan novice and first time poster, so please go easy on me.
We are considering taking the plunge and buying our first caravan for our family of 4. Our budget isn't exhaustive, just £5,000. I've done my research and taken on advice as to what I should be looking for; nothing older than 10 years ideal and something within our towing limit, 1200kg. We're happy to buy use, either through a dealer or privately (with proper checks and inspections carried out obviously), but as you can imagine the search range has been limited. Recently though I came across a local advert for a Sprite Firebrand 474 being sold privately. Having been to give the Caravan a look over it seems to be in good condition and with fixed bunks and extras such as the awning included, I think it could meet all our needs.
However, I've been getting increasingly confused as to whats permissible as the 'Gross Train Weight'. We drive a Ford C Max Grande (2014) 1.6 TDCi, which has a braked towing capacity of 1200kg (85% Kerb Weight, I believe). The Sprite's Maximum Technical Permissible Laden Mass is 1242kg. Presumably as long as we don't load the caravan to the max then we'll be OK to tow within the 1200kg limit. This part I think I've got clear in my head, where I'm struggling to understand is how does the tow limit effect what is deemed as an acceptable load to carry in the car itself. The car states that the Gross Train Weight as 3400kg, take way the 1200kg towing weight of the caravan and that leaves me with a figure of 2200kg. This figure corresponds to the figure stated for the Gross Vehicle Weight. If Gross Vehicle Weight doesn't take into account passengers or load in the car, then I'm lost as to how we're supposed to be able to transport ourselves and any luggage? I've obviously got lost with my thinking someway along the line, either that or my maths is a little rusty, but any advice to put me straight would be greatly appreciated.
3,956
Hello Dastrobby.
Vehicle weights can seem on the face of it very complex, but looked at carefully with consideration as to what they are describing they do actually make sense.
Lets start with your car. Using the figures you have supplied it seems it has a Gross Vehicle Weight (Also known as its GVW, GVM MAM...) of 2200kg. You have misunderstood this becasue it does describes the maximum weight the car can be importantly when it is fully loaded in other words with driver passengers and luggage.
This leaves a maximum braked towed load of 1200kg
I will comment that your point about the MTPLM being more than the towed weight limit is legally correct, BUT I do advise caution, because most caravanners find that they can all too easily start to creep up towards the MTPLM.
However in another twist of vehicle weight related fate, The MTPLM of a trailer is its maximum all up weight so crucially that is axle load and nose load added together. With a caravan of MTPLM 1242kg you will need to create a nose load of between 5%(60kg) and 7%(100Kg) (depending on the nose load limit of the car) which means the caravans maximum axle load will be between 1182 and 1142Kg.
As the nose load is legally carried not towed by the car, the car only tows the trailer's axle load, which is within the cars towed weight limit. This also means that as the nose load is applied to the car it is added to the effective weight of the car and you must make sure it does not cause the car to be overloaded on its own axles.
1,818
I think you need to check the MIRO (Mass in running order) of the caravan and then see what the difference is between that and the MTPLM to see if your proposal is feasible. If the difference between the MIRO and the 1200 towing capacity is less than 150kg I would think that keeping the weight down to the towing capacity will be very difficult. It might be achieved by always traveling with the water tank empty and loading the car rather than the caravan but all in all I think I would try to find a caravan with a MTPLM within the cars towing capacity
I did look up the caravan and if it is identical to the one found the match is possible as the MIRO is 1004 which would give you near 200 kg load allowance. If it has a motor mover that would eat into that figure probably by about 35kg but it depends on the model fitted.
Look at http://www.gocaravanning.com/caravan-specs/7894/Sprite-Firebrand-474-2005.html and http://www.caravantalk.co.uk/caravan-specifications/sprite/firebrand-474-2005_7803
3,956
JUst a quick note.
The MIRO of the caravan is at best a guess on the part of the caravan manufacture,uless they actiuallyweigh the caravan as it leaves the factory! so only consider it a guide not an absolute. However the MTPLM is an absolute, and regardless of what other weights or capacties you have you must never exceed the MTPLM.
1,818
You can get a copy of the brochure here, http://www.nationwidecaravanninguk.com/Brochure-Archive?brand=Sprite it appears it is probably a dealer special based on the Musketeer and might have extras that could add a bit to the weight. but do not know what.
Oct 14, 2016
Many thanks, some great advice here. It appears that the information personally sourced regarding Gross Vehicle Weight was misleading. Some more helpful advice from @ProfJohnL concerning what quantifies as axle load and what can be justified as nose load which puts my mind at ease a little more.
When considering what we would actually need to load into the caravan, I initially thought this would just be the awning and perhaps a table and chairs. With some more extensive research I've realised that this can be quite substantially more, bed lined, crockery, cooking utensils even gas bottles. However with the caravan in question having an MIRO of 1004kg this should give us 196kg of payload play with, does this seem an adequate amount to play with?
Oct 14, 2016
Thanks @Raywood, yes thats the correct model of caravan we're looking at. The difference between the MIRO and the vehicles towing capacity is 196kg. It does have motor overs though as well, so a figure more like 160kg seems realistic. An adequate amount to play with loading the caravan?
Oct 8, 2006
1,970
669
I'm not sure if there has not been some confusion here. PC's own pages show the following for a Ford C-max 1.6TDCi Zetec
Kerb weight 1426Kg
Noseweight 75Kg
Therefore 85% of 1426 is 1212Kg. 85% is just a number that someone thought up and is good advice for a driver who is a towing novice, but once a little experience is under the belt, up to 100% is not an issue.
Much more important is the noseweight. As Prof said the usual recommendation is a noseweight of around 7% of the caravan all-up weight - in this case about 85Kg. However the 75Kg - if that is correct - should never be exceeded as it can damage the car chassis above that. What is more if the towbar has a lower maximum then it is the lower figure that rules.
Mar 13, 2007
1,750
we managed for almost 11years on 71kg so yes more than adequate.
as the prof said the Mtplm. [mam] is an absolute, but the Miro is variable. working out the payload is easier if you imagine the Miro being the van and all the bits that go into it to make it work. so you start with the empty van add things like gas, battery, spare wheel, Ehu cable, motor mover. containers, pans, crockery. bedding. ect. that stay in the van all the time. get it weighed in this condition. and assume this is the vans Miro. the rest is user payload. this what I did and it left 71kg.
Feb 3, 2008
3,790
Kerb weight 1426Kg
Noseweight 75Kg
Yes, but the car's max braked tow weight is only 1200 kg, ie LESS than 85%. :(
Oct 8, 2006
1,970
669
Curious isn't it then that both PC and Parkers list this vehicle as 1300Kg maximum braked trailer weight?
1,818
It does not matter what the guides say the unbraked trailer weight is, the law is based on the maufacturers figures so stick with that.
As far as the load allowance is concerned 160kg is often the maximum the caravan manufacturers allow on some models and is manageable. I would say however if you have heavy items like an awning keep these in the car.
Jun 2, 2017
141
yeezy boost 350
jerseys cheap
coach outlet online
heat jerseys
phillies jerseys
cowboys jerseys
hermes bags
discount nike shoes
oakley sunglasses outlet
michael kors outlet store
louis vuitton bags
yeezy boost
mont blanc pen
michael kors outlet
adidas uk
birkenstock outlet
louboutin pas cher
nike outlet
toms
burberry outlet online
kate spade handbags
purs jerseys
adidas outlet store
cheap jerseys
toms
coach factory outlet online
cheap nike sneakers
nfl jerseys
louboutin outlet
longchamps
air max outlet
ralph lauren sale
adidas running shoes
coach handbags outlet
birkenstock shoes
coach outlet online
true religion
pandora charms
fitflop shoes
nike outlet store
ralph lauren outlet
adidas nmd r1
yeezy shoes
air max
nike outlet store
coach outlet online
michael kors
coach outlet store online clearance
hermes bag
kate spade bags
moncler uk
versace
cheap jordans for sale
prada outlet online
ralph lauren outlet online
louis vuitton factory outlet
gucci borse
mont blanc pen
swarovski sale
coach outlet online
kate spade outlet online
mulberry uk
coach purses
jordans
tory burch outlet online
adidas outlet online
giants jerseys
adidas nmd runner
gucci outlet online
adidas nmd runner
adidas outlet store
yeezy boost 350
beats by dre
rolex replica watches
nike outlet
moncler uk
gucci handbags outlet
ralph lauren sale
coach outlet store
kd shoes
cheap jordan shoes
polo ralph lauren outlet online
sac longchamp
burberry outlet store
ralph lauren outlet
kate spade outlet store
harden shoes
pandora jewelry
pandora charms sale clearance
michael kors handbags outlet
polo ralph lauren
christian louboutin
dansko outlet
texans jerseys
ralph lauren sale
fitflops
fendi bags
air max 90
dodgers jerseys
eltics jerseys
louis vuitton outlet online
longchamp bag
rolex replica watches for sale
chaussures louboutin
nike free 4.0 flyknit
rolex watches
coach outlet store
yankees jerseys
montblanc
pandora charms
fitflops sale clearance
pandora
coach outlet online
nike free run flyknit
nfl jerseys cheap
curry shoes
ray ban sunglasses outlet
christian louboutin outlet
adidas nmd runner
nike air max 95
marc jacobs
christian louboutin shoes
adidas ultra boost
ray ban sunglasses discount
cheap jordan shoes
adidas superstars
hermes outlet online
oakley sunglasses on sale
cardinals jerseys
michael kors outlet clearance
abercrombie outlet
marc jacobs outlet
hermes outlet
cheap rolex watches
pandora charms
air max 90
nike free run
nike outlet store online
longchamp handbags
yeezy boost
true religion jeans
ralph lauren sale
tory burch sale
coach outlet online
fitflops clearance
air max
cheap jordan shoes
michael kors outlet online
nike sneakers
coach outlet online
yeezy boost 350
louboutin outlet
coach outlet online
gucci outlet online
air jordans
coach outlet store
discount oakley sunglasses
moncler pas cher
polo ralph lauren
mulberry bags
sac louis vuitton pas cher
coach outlet online
ray bans
michael kors bags
adidas
toms outlet
coach outlet store
michael kors
mont blanc pens
broncos jerseys
sac louis vuitton
birkin handbags
swarovski uk
fake rolex watches
clarks shoes outlet
wireless beats headphones
salomon boots
birkenstock outlet
ralph lauren
jordan shoes
fit flops
coach outlet store
louis vuitton outlet store
adidas nmd r1
gucci
red bottom shoes for women
mulberry handbags
adidas nmd r1
christian louboutin sale
swarovski crystals
ralph lauren outlet
rangers jerseys
mulberry outlet uk
mlb jerseys
true religion jeans outlet
pandora jewelry outlet
fitflops clearance
beats wireless headphones
burberry sale
bercrombie
tods outlet
fitflop shoes
cheap nike shoes
cheap nfl jerseys
kd 8 shoes
salomon outlet
nike outlet online
burberry outlet
michael kors bags
jimmy choo shoes
ed hardy store
fred perry polo shirts
cheap oakley sunglasses
valentino outlet
pandora charms outlet
air max shoes
nike store
dolce and gabbana outlet online
yeezy boost
toms outlet
fitflops sale
michael kors outlet canada
nike roshe one
gucci
49ers jerseys
moncler jackets
mbt
michael kors
ralph lauren outlet
adidas
yeezy boost 350
nike air max
yeezy 350 boost
michael kors bags
ralph lauren
patriots jerseys
adidas nmd r1
michael kors uk
coach outlet online
nike blazer low pas cher
pandora bracelet
nike air max 95
red sox jerseys
gucci bags
coach outlet online
air jordan shoes
nike flyknit
christian louboutin
mulberry uk
moncler outlet online
levis outlet
toms
nike roshe shoes
longchamp soldes
longchamp outlet store
hollister clothing
coach outlet canada
lakers jerseys
kate spade uk
longchamp bags
michael kors
ralph lauren sale clearance uk
moncler jackets
chi flat iron
jordan shoes
hermes bags
polo ralph lauren
mulberry
ralph lauren
clarks shoes outlet
coach outlet online
nfl jerseys
coach outlet
michael kors
mlb jerseys
adidas sneakers
longchamp bags
adidas store
hollister kids
beats headphones
nike cortez classic
tigers jerseys
warriors jerseys
pandora jewelry
salomon outlet
cheap air jordans
longchamp pliage
nike air force
michael kors outlet
louis vuitton purses
michael kors
nfl jerseys wholesale
adidas superstars
packers jerseys
longchamp handbags
fitflops sale
michael kors
red bottom
pandora outlet
white sox jerseys
fitflops sale
mbt
air max
clarks
nmd adidas
cheap ray ban sunglasses
coach outlet online
adidas yeezy boost 350
burberry outlet
cavaliers jerseys
air jordans
adidas sneakers
true religion outlet online
fred perry shirts
adidas trainers
polo ralph lauren pas cher
cheap jordan shoes
pandora jewelry store
red bottom heels
eahawks jerseys
ed hardy outlet
coach outlet online
louboutin shoes
nike uk
clarks shoes for women
parada bags
longchamp sale
yeezy shoes
bulls jerseys
moncler coats
nike outlet store
vans outlet
vans store
timberland boots outle
ray ban glasses
christian louboutin pas cher
cheap jordan shoes
rolex watches
jordan retro
yeezy boost
oakley sunglasses wholesale
nike tn pas cher
jordan femmes pas cher
rockets jerseys
cheap rolex replica watches
adidas nmd runner
montblanc pens
coach outlet online
gucci bags
birkenstock uk
adidas yeezy boost
thunder jerseys
jordan uk
louboutin outlet
birkenstocks
sac longchamp
ghd straighteners sale
adidas yeezy boost
coach outlet online
fitflop
adidas yeezy boost
birkenstock
celine outlet online
air max 90
fitflop
birkenstock outlet
ed hardy clothing
nike sneakers
fit flops
louboutin shoes
ray ban sunglasses cheap
ed hardy uk
adidas trainers
ralph lauren
chaussure louboutin pas cher
ghd hair
nike air huarache
ray bans
yeezy boost 350 v2
ray ban glasses
coach outlet online
coach factory outlet store
adidas superstar trainers
michael kors
polo ralph lauren
adidas superstar shoes
mlb jerseys whgolesale
pandora charms sale
tods shoes
birkenstocks
celine handbags
yeezy shoes
red bottom
kate spade outlet
kate spade bags
mbt
fitflops sandals
mlb jerseys
coach outlet online
cheap air max
longchamp bags
dansko
adidas sneakers
michael kors uk
adidas yeezy boost
cubs jerseys
ralph lauren uk
coach outlet online
fit flops
louboutin outlet
kate spade purses
pandora charms sale
dewdef
