Hi
I tow with 2009 407 sw 140 so slightly higher weights however see attached
Towing Report
Peugeot and Sprite The
towing capability for the Peugeot 407 SW - 1.6 HDI 16v [1300 trek]
with a Sprite Alpine 4:
Performance on levelled roads
Top speed
Usability 5th gear
Acceleration and take over
Performance in mountainous regions
Drive off uphill
Driving on motorway slopes
Driving on steep roads
Peugeot 407 SW - 1.6 HDI 16v [1300 trek] (80 kW/107 bhp)
Date of manufacture: august 2005 - february 2011
77%
1199 kg 1567 kg Important for safe towing is the weight ratio between Car and Caravan. The weight ratio (loaded caravan / kerbweight tow car) for the Peugeot and Sprite is
77%. The match between car and caravan is perfect.
The towing performances of this Peugeot with your Sprite are good (performance index = 57).
You may expect more than adequate performances from this outfit. On flat roads you can come along provided you've selected the right gear, in which case top gear is applicable in most cases.
On motorway inclines you will be able to come along quite nicely. On steep roads you have more than sufficient power to keep going. On hill starts there will be sufficient power to get going, provided the wheels have traction.
57
16%
