chrisbee 1 said:
Reg said:
It's not my normal practice but I have towed above 75mph overtaking large lorries going down hill just to satisfy myself that is stable.
Perhaps not the safest way to test stability?
I test stability this way every time i tow.
The rig always tows different every time out, even through the nose weight is around the same, the loading also, tyre pressures correct etc.
Even so the prevailing conditions while towing are rarely the same.
Roads vary, traffic density, wind, weather, all these guide me to tow at the most stable speed, safe speed if you like.
For example last time out was gale force winds, gust upto 60mph, motor speeds at times was restricted to 40mph!, i towed down to 30mph, lorries constantly passing.
But when conditions allow i will tow upto 60mph.
So yes speed is the best way to test stability, which is way the annual tow car tests tow up to 70mph.
