New to this
Jun 3, 2025
Hi! We've just bought our first caravan - a Swift Challenger 560 (new to us) - and we're driving from Glasgow to Nottingham later this month to collect it. We're so nervous about towing! We've looked into courses but haven't been able to find one that would work in with our dates. I'm just hoping we'll be okay on the drive back north and also using the motor mover to reverse the caravan into our drive. Hopefully we'll be ok!
Sep 23, 2023
1,084
414
1,435
Welcome aboard,just take your time, there's no point in dashing about(I've forgot how to 🙂). probably best to set off home at a quiet time of day,,take a flask and have 20 mins somewhere to break journey,,,Good luck,,, Gary
Reactions: Didi
Jun 3, 2025
Thanks so much, Gary! I wonder which are the best services to stop on the M6 with a caravan? Are there dedicated spaces for cars with caravans?
3,100
Your obvious route home is to go north up the M1, then A1(M) to Scotch Corner, A66 to Penrith and then M6/A74(M)/M74 up to Glasgow. Stick to 55 on the motorways, same speed as the trucks.
Wetherby services on the A1(M) have drive-through caravan spaces - but gets very busy at peak times. It's less than halfway from Nottingham-Glasgow but may be a good choice to reflect on your first hour or so's towing.
Reactions: Didi
Jun 3, 2025
Thanks, Roger! That's really helpful :)
May 30, 2024
75
74
635
Whether it's a dealer or private purchase, make sure that they take the time to go through everything with you and help make sure that you're hitched up and checked properly, that you've got your extender mirrors adjusted correctly and that the caravan lights are working correctly.
When you set off, you'll be surprised that it is easier to get moving than you perhaps expect, and keep telling yourself 'remember that I'm wide'. Take quite a slow, wide line around corners, but you can see in your mirrors how close you are to the kerb and get used to where you need to be. Once you've got accustomed to it, you won't always be massively aware of any feeling that you are towing, but do stay below 55mph until you feel comfortable and genuinely capable.
My experience is that 95% of other road users are generous towards you, giving you space and so on. Just occasionally, you'll come across someone who makes life difficult, but just be relaxed about it.
Using the motor mover is easy peasy. The only thing you're likely to get wrong is forgetting to release the handbrake (or apply it) before and after.
Reactions: Didi
2,428
Hi Didi Welcome to the forum when you pick up the caravan take it nice steady until you feel confident and in a couple hours and I would stop at a service station for a break good luck
