New Truma heater clicks like a machine gun
Jul 17, 2005
145
Hi Van Lovers
Okay its summer but on the first outing of the new member of the family, a swift 540 it was cold in the rain with all the windows open.....so time to try the new heater(well did not want to wait to November)
Heater set on blow air, about 2.5 on the speed dial...after 20 mins or so nice and warm...40 mins later enjoying the warm inner van there was a noise that sounded like a hand held drill reaching the tension and clicking, we thought a van had parked near by and some was putting down the corner steadies.
40-50 mins later another short burst of clicking...after a while the same again...at this point during the click I got up and found the sound was coming from the back of the heater.
During the evening I varied the speed and temp but the clicking continued very adhoc and different time spans from the occasional click to a machine gun.
The next day I tried using the heater for cold blow only and no clicks.
Now to take it back to the dealer at this stage would be a pain in the a**e, is it a hot metal bedding in thing or is likely to get worse...your thoughts would be much appreciated.
Apart from this the van is top banana.
F
I recognise that noise you describe,What you will find it is Volt drop from the site mains,the noise is the relays chattering on the element control pcb at the back of the heater.
This usualy occurs when the site supply voltage drops down to about 200 volts.
I will put money on it that if you try it at home or another site it will be perfect.but don,t continue to use the heater whilst it is making that noise or you will need a new pcb.or at least the 3 element control relays replacing.I have mended quite a few of these pcb,s now. Glenn
Jul 17, 2005
145
Thanks for that, off to Clumber the weekend after next so will try it again.
F
