- Apr 11, 2021
- 20
- 4
- 15
I'm Colin and I've just joined this forum as my wife and I have just been on our first outing in a new (to us) van and I need some technical assistance, if I may?
I'll also try and help others if I can, as I realise this shouldn't be a one-way street.
Our week on the Llyn Peninsula was really good and apart from enjoying the wonderful landscape and coastline it was great to find out how our 8 year old Adria Adora worked.
But I have two big problems to solve and I'd like some assistance please?
1. Truma water heater
Although I made a checklist for leaving the CL site we stayed at, I stupidly forgot to turn our Truma water heater electric switch off before I drained the water from the van's pipes. It wasn't until half an hour after I'd put the yellow valve lever into the upright position that I realised the switch on the front of the lounge seat was still in the on position, and I started banging my fist against my knees for being such an idiot.
Have I caused irreparable damage to the immersion element? If so, can it be replaced by me or must it go to a garage for an expensive professional job? Or does the entire boiler need replacing? I haven't checked anything since as we were coming home.
2. Water pump and pressure regulator
We had recurring issues with our water supply from the Aquaroll, using a Truma pump. When we arrived at the site and connected the water up, we heard a lot of noise from the pump or water pressure regulator - I couldn't tell which.
Because the pump was new from the dealer I suspected the problem was with the pressure regulator. I asked a fellow caravanner who thought the problem might be with the pressure regulator and suggested I turned the white knurled knob on top until the noise stopped and the flow through the taps was good.
This advice was repeated when I rang the dealer we bought the van from, who advised me to turn the hot tap on whilst turning the pressure regulator knob until a clicking noise was heard. I did this but rather than me hearing a clicking noise at the regulator, my wife heard it at the tap!
Anyway, I stopped at this point as the tap flow was good and the bad pumping noise had stopped and was now a normal hum.
BUT: The pump humming noise didn't stop when the tap was turned off, so we spent the rest of the week turning the main pump switch on and off by the door, whenever we wanted to use the taps - which was a real pain. The reason we carried on like this was because we didn't want to disturb the regulator again in case the original problem noise came back.
So I would really appreciate any help on how to solve these two problems.
Many thanks in anticipation.
