nissan x trail
Sep 12, 2007
83
is the x trail a good match to go with a sterling europa 550
many thanks in advance
Apr 14, 2008
116
No idea what size a sterling europa 555 is, but I tow a Hymer (MTPLM 1600kg) with a 55 plate diesel (136 hp DCI) and it is fantastic.
Cruises at 60 mph, accelerates well even uphill, and very stable over the 5000+ miles I have used it. It has a 100kg towbar limit with a short overhang from the rear wheels which helps a lot. Fuel consumption is about 37mpg solo running about generally, and towing on motorway gives 26mpg. These figures are corrected for the wildly (10%) overreading speedo which I have accurately calibrated over 100miles of motorway with reference to the marker posts, some maths required as these are in km!
Additionally you get a great view driving with a large sunroof as well, and a proper full size spare wheel.
Yes there are turbo problems with this model, mine has had to be replaced but Nisssan paid, most should be done by now.
We love our X trail our is the 03 reg model 112bhp, but we are happy with it, I get 35 short run and 44 long run and 28 to 32 to the gallon towing, had it for 4 years now will keep it bit longer, Trevor123
Mar 10, 2006
3,274
47
Which xtrail are you asking about, model, tpye?
The latest model T31,
or the T30 which was replaced in 2007 ish.
Some T30's were two wheel drive, avoid.
Oct 24, 2007
96
I had a 55plate SVE Great tow car untill the turbo went Aug 09, had it replaced & intercooler £1350.00 went again while towing my Coachman Pastiche 560 @ Exeter, replaced again now I have got rid of it as I lost confidence in it while towing,( Santa Fe on order )
my brother has xtrail as well with no problem, towing a Bailey Senata
Mar 10, 2006
3,274
47
I would make sure its the 134bhp model available from late 2003 i believe.
I had the 2004 SVE which is a great tow car. Kerb weight 1650 kg.
While i had the inter cooler replaced, the car is still on its original turbo. My son still runs it.
You must make sure the boost sensor has been replaced under recall, or the ECU reprogrammed, or both, i just had the sensor replaced.
If you go for the 112bhp? model, these had some issues with injectors, look for black smoke from the exhaust.
And rattly time chains, due usually to the chain tensioner failing i believe.
Note both engines sound very noisy when first started up, this is normal.
May 12, 2011
364
We tow a 2010 Swift Charisma 550 (which is possibly almost identical to yours) with our 2009 173 ps X-Trail. MTPLM vs Kerbwieght is probably around 85% (1495 vs ~1750) but we put virtually anything of any weight in the car and have no problems with stability. Power is more than adequate, we hauled up some steep hills around the French Alps this summer with no concerns at all.
