No gas in van
Jun 24, 2006
8
I'm getting no gas in my Bailey caravan. The Truma regulator appears to be working as I have gas coming out of the BBQ point which is the van side of the regulator - or is it allowing gas out at the incorrect pressure so the cooker does not work at this pressure?
I have also opened the T piece on the other side of the BBQ connection and gas is coming through.
None of the gas appliances work. All inlet valves have been opened. I am using Butane from a 7Kg bottle, but it is a couple of years old - probably 2003/4.
Am I missing something obvious?
Gary have you looked in the cupboard near the oven at low level there is a set of gas isolation valves for all the appliances. check the incomming valve on the manifold it could have been knocked into the off position. By someone else of course LOL
Jun 24, 2006
8
I've checked those many times over. Would the Truma valve operate but at the wrong pressure for the various units?
354
It is possible that the gas bottle is low in gas therfore low in presure. There may just be suficient presure for the BBQ point but not the van. Try a fresh cylinder.
Jun 24, 2006
8
I was wondering whether that may be the case because the gas is low. I'll give it a try. Thanks.
Jun 24, 2006
8
I have tried two bottles - admittedly both on the low side, but working last year.
354
I have in the past used gas bottles for our cadac that werent able to give enough presure in the van. Remember there is a lot more pipe work in the van to be presurised.
we have a stoves hob with a glass lid in our swift. If the lid is not right up ( last 1/4 inch ) the gas cut of valve isolates the cooker. changed a bottle before i found this regards Bob
Gary, We had a similar problem with our old crown van immediately after it was serviced. In our case it turned out to be a tiny bit of water in the gas pipe ( left there from the dealers method of pressure testing the gas pipes ). Try running your space heater on gas,If it works then the problem lies with the cooker supply. In our case we managed to get the oven working, which in turn heated the pipework on the hob enough to turn the water into steam, which then came through the cooker jets !.
4,465
Hello Gary,
Because gas systems in caravans are used far more infrequently than normal domestic appliances, the equiepment will deteriorate just becuase of time.
If you have gas available at the BBQ point then that suggests that the regulator is working, so the problem is either with the pipe work or the other appliances.
It is not possible for anyone to accuratly diagnose your difficulties on this forum, so I would recommend that you arrange to have the whole system checked by a gas fitter who can check things first hand.
DMT
Hi Gary,
I had the same problem with my new avondale in 2004, the gas would not light so i followed all the usual checks, all seemed fine so i decided to remove the flexible pipe that connects the gas bottle to the caravans regulator, when i blew down it i found it had a one way valve inside and had fitted it the wrong way round, once swapped the other way all was ok and has been eversince.
Hope this solves your problem
Dave.
Hi Gary.
We had the same issue last weekend traced the fault to the Truma regulator, luckily our dealer was only 10 mins drive from where we was sited, so a quick trip up the road, the conversation that then followed was that, all the failures that they have been involved with was the use of Butane not Propane, and you have guessed we used Butane, they gave me a replacement and exchange my full bottle of Butane for a larger Propane (paid the difference for the extra gas), fitted the new regulator no more problems, so if like me it looks like the regulator to me, this is a problem that Truma are looking into, currently they are in a legal argument with Calor over the failures.
Carlton.
Hi folks - use propane all year except summer in France when I use Camping Gaz (refills obtainable on continent). Is there an issue with Camping Gaz butane or is it just with Calors.
4,465
Hello John,
Camping Gaz is basically Butane, and not really any different to Calor Butane. Most UK caravans will run happily on either Butane or Propane, provided the appropriate regulator is used.
There are several different standards that have been used for gas pressures in the UK. Traditionally we used 28mB for butane and 37mB for propane, but more recently a common 30mB standard has been adopted for both gas types.
Check in your caravan hand book, or look at any of gas burning appliances and a data plate should tell you which standard applies. If in any doubt consult your dealer
As for your choice of Propane in the UK and Camping Gaz in France, there is some much sense to that, for two reasons, firstly, for any given ambient temperature Propane will have a much higher bottle pressure than Butane which might have safety implications in a hot Frech summer. secondly camping gaz is more widely available and it reduces the number of regulators or connections you need to take with you.
Hi John - thanks for response. I thought maybe the issue with Calor butane was more to do with the way Calor process/produces/makes its gas. Someone informed me that it was to do with "impurities" contained within the Calor product. Just wondered if it was the same for Camping Gaz production!
4,465
Hello again John,
When you purchase Propane or Butane LPG for use in caravans, it is the commercial grade which will contain other fractions of the LPG's. to achieve a particular combustion or usage performance. This is not uncommon and is allowed wthin the international commercial standards for the definitions of the gasses.
Other non LPG impurities may creep into the mix but but these are unlikely to vapourise, and so will collect at the bottom of the bottle. These impurities will not cause a problem provided the bottle is stored transported or used in the upright attitude.
From my own experience when impurities get into the pipework, it is down to poor bottle handling, or the wrong grade of flexible pipes which can be partially disolved by the LPG. The residue is a thick oily type of deposit that blocks up the small jets in gas burners, or clogs gas valve ports.
It is unlikely that the problem is soley related to one brand of gas. Even though there are many differnt brand names, it is likely that in any given area, the different brands are all sourced from a limited number of manufactures.
, as with many petrolium products they come from a limited number of prime sources and are bottled and badged
Jun 2, 2017
141
yeezy boost 350
jerseys cheap
coach outlet online
heat jerseys
phillies jerseys
cowboys jerseys
hermes bags
discount nike shoes
oakley sunglasses outlet
michael kors outlet store
louis vuitton bags
yeezy boost
mont blanc pen
michael kors outlet
adidas uk
birkenstock outlet
louboutin pas cher
nike outlet
toms
burberry outlet online
kate spade handbags
purs jerseys
adidas outlet store
cheap jerseys
toms
coach factory outlet online
cheap nike sneakers
nfl jerseys
louboutin outlet
longchamps
air max outlet
ralph lauren sale
adidas running shoes
coach handbags outlet
birkenstock shoes
coach outlet online
true religion
pandora charms
fitflop shoes
nike outlet store
ralph lauren outlet
adidas nmd r1
yeezy shoes
air max
nike outlet store
coach outlet online
michael kors
coach outlet store online clearance
hermes bag
kate spade bags
moncler uk
versace
cheap jordans for sale
prada outlet online
ralph lauren outlet online
louis vuitton factory outlet
gucci borse
mont blanc pen
swarovski sale
coach outlet online
kate spade outlet online
mulberry uk
coach purses
jordans
tory burch outlet online
adidas outlet online
giants jerseys
adidas nmd runner
gucci outlet online
adidas nmd runner
adidas outlet store
yeezy boost 350
beats by dre
rolex replica watches
nike outlet
moncler uk
gucci handbags outlet
ralph lauren sale
coach outlet store
kd shoes
cheap jordan shoes
polo ralph lauren outlet online
sac longchamp
burberry outlet store
ralph lauren outlet
kate spade outlet store
harden shoes
pandora jewelry
pandora charms sale clearance
michael kors handbags outlet
polo ralph lauren
christian louboutin
dansko outlet
texans jerseys
ralph lauren sale
fitflops
fendi bags
air max 90
dodgers jerseys
eltics jerseys
louis vuitton outlet online
longchamp bag
rolex replica watches for sale
chaussures louboutin
nike free 4.0 flyknit
rolex watches
coach outlet store
yankees jerseys
montblanc
pandora charms
fitflops sale clearance
pandora
coach outlet online
nike free run flyknit
nfl jerseys cheap
curry shoes
ray ban sunglasses outlet
christian louboutin outlet
adidas nmd runner
nike air max 95
marc jacobs
christian louboutin shoes
adidas ultra boost
ray ban sunglasses discount
cheap jordan shoes
adidas superstars
hermes outlet online
oakley sunglasses on sale
cardinals jerseys
michael kors outlet clearance
abercrombie outlet
marc jacobs outlet
hermes outlet
cheap rolex watches
pandora charms
air max 90
nike free run
nike outlet store online
longchamp handbags
yeezy boost
true religion jeans
ralph lauren sale
tory burch sale
coach outlet online
fitflops clearance
air max
cheap jordan shoes
michael kors outlet online
nike sneakers
coach outlet online
yeezy boost 350
louboutin outlet
coach outlet online
gucci outlet online
air jordans
coach outlet store
discount oakley sunglasses
moncler pas cher
polo ralph lauren
mulberry bags
sac louis vuitton pas cher
coach outlet online
ray bans
michael kors bags
adidas
toms outlet
coach outlet store
michael kors
mont blanc pens
broncos jerseys
sac louis vuitton
birkin handbags
swarovski uk
fake rolex watches
clarks shoes outlet
wireless beats headphones
salomon boots
birkenstock outlet
ralph lauren
jordan shoes
fit flops
coach outlet store
louis vuitton outlet store
adidas nmd r1
gucci
red bottom shoes for women
mulberry handbags
adidas nmd r1
christian louboutin sale
swarovski crystals
ralph lauren outlet
rangers jerseys
mulberry outlet uk
mlb jerseys
true religion jeans outlet
pandora jewelry outlet
fitflops clearance
beats wireless headphones
burberry sale
bercrombie
tods outlet
fitflop shoes
cheap nike shoes
cheap nfl jerseys
kd 8 shoes
salomon outlet
nike outlet online
burberry outlet
michael kors bags
jimmy choo shoes
ed hardy store
fred perry polo shirts
cheap oakley sunglasses
valentino outlet
pandora charms outlet
air max shoes
nike store
dolce and gabbana outlet online
yeezy boost
toms outlet
fitflops sale
michael kors outlet canada
nike roshe one
gucci
49ers jerseys
moncler jackets
mbt
michael kors
ralph lauren outlet
adidas
yeezy boost 350
nike air max
yeezy 350 boost
michael kors bags
ralph lauren
patriots jerseys
adidas nmd r1
michael kors uk
coach outlet online
nike blazer low pas cher
pandora bracelet
nike air max 95
red sox jerseys
gucci bags
coach outlet online
air jordan shoes
nike flyknit
christian louboutin
mulberry uk
moncler outlet online
levis outlet
toms
nike roshe shoes
longchamp soldes
longchamp outlet store
hollister clothing
coach outlet canada
lakers jerseys
kate spade uk
longchamp bags
michael kors
ralph lauren sale clearance uk
moncler jackets
chi flat iron
jordan shoes
hermes bags
polo ralph lauren
mulberry
ralph lauren
clarks shoes outlet
coach outlet online
nfl jerseys
coach outlet
michael kors
mlb jerseys
adidas sneakers
longchamp bags
adidas store
hollister kids
beats headphones
nike cortez classic
tigers jerseys
warriors jerseys
pandora jewelry
salomon outlet
cheap air jordans
longchamp pliage
nike air force
michael kors outlet
louis vuitton purses
michael kors
nfl jerseys wholesale
adidas superstars
packers jerseys
longchamp handbags
fitflops sale
michael kors
red bottom
pandora outlet
white sox jerseys
fitflops sale
mbt
air max
clarks
nmd adidas
cheap ray ban sunglasses
coach outlet online
adidas yeezy boost 350
burberry outlet
cavaliers jerseys
air jordans
adidas sneakers
true religion outlet online
fred perry shirts
adidas trainers
polo ralph lauren pas cher
cheap jordan shoes
pandora jewelry store
red bottom heels
eahawks jerseys
ed hardy outlet
coach outlet online
louboutin shoes
nike uk
clarks shoes for women
parada bags
longchamp sale
yeezy shoes
bulls jerseys
moncler coats
nike outlet store
vans outlet
vans store
timberland boots outle
ray ban glasses
christian louboutin pas cher
cheap jordan shoes
rolex watches
jordan retro
yeezy boost
oakley sunglasses wholesale
nike tn pas cher
jordan femmes pas cher
rockets jerseys
cheap rolex replica watches
adidas nmd runner
montblanc pens
coach outlet online
gucci bags
birkenstock uk
adidas yeezy boost
thunder jerseys
jordan uk
louboutin outlet
birkenstocks
sac longchamp
ghd straighteners sale
adidas yeezy boost
coach outlet online
fitflop
adidas yeezy boost
birkenstock
celine outlet online
air max 90
fitflop
birkenstock outlet
ed hardy clothing
nike sneakers
fit flops
louboutin shoes
ray ban sunglasses cheap
ed hardy uk
adidas trainers
ralph lauren
chaussure louboutin pas cher
ghd hair
nike air huarache
ray bans
yeezy boost 350 v2
ray ban glasses
coach outlet online
coach factory outlet store
adidas superstar trainers
michael kors
polo ralph lauren
adidas superstar shoes
mlb jerseys whgolesale
pandora charms sale
tods shoes
birkenstocks
celine handbags
yeezy shoes
red bottom
kate spade outlet
kate spade bags
mbt
fitflops sandals
mlb jerseys
coach outlet online
cheap air max
longchamp bags
dansko
adidas sneakers
michael kors uk
adidas yeezy boost
cubs jerseys
ralph lauren uk
coach outlet online
fit flops
louboutin outlet
kate spade purses
pandora charms sale
dewfref
