I've been having problems with the charger unit on my 2009 Sterling Europa since new. I've reported faults with it 7 times. It's been replaced 5/6 times now. I know from researching on various forums that there were issues with an incorrectly spec'ed component (Transformer - If I remember correctly), but I am still getting recurring problems almost every time I use the van. - Which is rare as the van spends so long in the dealers.
I know Swift have since swapped to a different manufacturer but I've come to the conclusion that there's a design fault with these Nordelettronica NE143 units.
Referring to the latest problem; I lose all 12v output from the charger. First indication of a problem is when I notice the lights are running dim as the battery discharges. (I've had this problem before but have also had intermittant problems on previous units where the 12v output has failed but then recovered days later. I've also monitored unregulated output from the unit resulting in overcharging of the battery)
Can anyone tell me what is the maximum current of the 12v supply of this unit is? The reason I ask is because I've seen a label on the outside of the unit mentioning 17A maximum, but I've discovered there's a fuse on the back of the case at 30A. This fuse is only accessable once the unit is removed from it's housing so is obviously not intended as a "user-replaceable" item. If, as is stated on the case it's a 17A max, then that leaves several questions:
Why is there a 30A fuse?
Why is there no mention of this fuse in any circuit diagrams or other owner documentation?
What is there to protect the Charger unit from an overload?
Kevin
Kevin
