Omnivent failed
Mar 2, 2010
1,231
19,185
The fan motor has died and a new none is £86 from Leisure direct they also do a complete fan for £106 which I would rather have to get the control pack in case that fails.Has anyone else had motor problems and found anywhere not so expensive?(Series 6 Indiana btw)
4,271
Dave
See the web site below. As far as I know they have the rights to sel the genuine thing. Their price list is in euros and tehy ae near Weymouth in Dorset.
Good luck
" http://www.omnistor.com/gb/products/omnivent.php"
Cheers
Dustdyog
Mar 2, 2010
1,231
19,185
Thanks for that I'll call them Monday.The motor is shown but not priced.I noticed they have an LED kit for the surround,has anyone fitted one of these?
4,271
Dave
See below the full euro price list.
The motor comes with the fan blades part no 51 9019 00
at Euro 61.98.
Is that the bit you need? Hope it isn't something else?
Cheers
Dustydog
Spare parts Omni-Vent
End user prices excl. VAT
ART. NR DESCRIPTION EURO
07 1904 INNER HATCH FRAME 6,34
07 1921 VENTILATOR FRAME 15,84
07 1952 INNER HATCH FRAME > 2004 CREAM 7,41
23 6001 00 RETROFIT CURTAIN FRAME V04 *
51 9001 00 MOSQUITO SCREEN 6,56
51 9010 00 FIXATION OMNI-VENT 6,17
51 9011 00 FIXATION OMNI-VENT 04 6,19
51 9012 01 ELECTRONIC CONTROL WITH THERMOSTAT 131,22
51 9014 00 CURTAIN FRAME WITH ROLLO 26,25
51 9017 00 OUTER HATCH FRAME WITH HINGE 11,48
51 9018 00 KNOB WITH SQUARE SHAFT 3,60
51 9019 00 MOTOR + FAN BLADE VENTILATOR 61,98
51 9020 01 CONTROL SYSTEM - 3 SPEED 47,57
51 9020 02 CONTROL SYSTEM - 1 SPEED 33,95
51 9021 01 VENTILATOR GRID 12V ELECTRIC 6,56
51 9021 02 VENTILATOR GRID ELECTRONIC 8,52
51 9023 00 DOME TRANSPARENT WITH OPERATING DEVICE > 2004 75,75
51 9023 01 DOME 04 + OP. DEVICE OMNIVENT WHITE 44,70
51 9023 02 DOME 04 + OP. DEVICE OMNIVENT TRANSLUCENT 44,70
51 9028 00 KNOB WITH SQUARE SHAFT > 2004 3,70
63 0007 00 LED LIGHTING 4X4 OMNI-VENT > 2004 170,44
51 9011 00 RETROFIT LOCK ASSY 2,42
51 9042 00 MOSQUITO NET V08 9,70
51 9043 00 ELECTRICAL DEVICE V08 42,02
51 9044 00 VENTILATOR GRID V08 9,00
55 9004 00 OPERATING DEVICE OMNIVENT 15,72
63 0002 00 VENTILATOR 12V + THERMOSTAT
Mar 2, 2010
1,231
19,185
Hi,couldnt find that.Am sure it is motor,have removed it and put wires direct to battery and motor tries to start without success.Would be more than happy with that price.Van is less than 3 years old but going to dealer for checking then again for replacement would be dearer than buying assuming fan has 3 year not one year warranty.Its not always clear what is and isn't covered.Also Bailey go on break this time of year so it will be September before anything gets fixed.
Thank you again for your help
Jun 16, 2010
370
164
18,735
Same thing happened to my fan a few weeks ago
Just like yours, tested the motor across the battery and it thought about turning but not much else.
Got a second hand one from a caravan breakers in Creswell -
Feb 27, 2010
633
its probably the brushes in the motor and very easy to fix your self.
The brushes ( these supply 12v to the commutator which makes it turn) are probably dirty and need a clean.
You will have to take the motor apart but anyone who can change the oil in their car can work it out for themselves, or just google the instructions.
Mar 2, 2010
1,231
19,185
Having looked at it the rivets are quite rusty and am wondering if rain has settled in the rivet recesses making its way into the motor and corroding the connections inside.Have found a motor for
Mar 2, 2010
1,231
19,185
Have fixed it ,removed the grommet where the wires enter the fan and you can see the commutater.The wires seemed to have moved inside the fan and caused the brushes to lose contact.Stretched the wires and put grommet back and all is fine.Used a small tiewrap to tighten the grommet to wire and am hoping for the best.
Will also get some electrical cleaner as it would be easy to spray through the grommet hole to clean brushes etc.
Thanks to all for advice and postings
Feb 27, 2010
633
thats saved you a few quid.... can have some commission?... whats that.... no?.
we live in a throw away society and far too many people will just buy a new one thinking that the item thats out of service can niot be repaired.
Sep 6, 2011
Just for info, I have had the same problem with my Omnivent. Fortunately I have managed to fix it and the good news is it's really simple. In fact the rivets do not need to be removed at all. They need to stay in place as they hold the brushes in place. In fact the top of the motor simply prises off! Just get a sharp but sturdy blade and insert it between the lid of the motor and the base. The strong magnet on the motor does try to hold the lid in place, but if you work your way round it comes off OK. The common problem seems to be that the brushes stick in the holder. They have used a very weak spring, so it doesn't take much. After easing the brushes off and a drop of WD40 I reassembled it with a smear of silicone sealer round the top and it is now perfect.
Hope that helps someone else and saves them £90...
Sep 6, 2011
Oct 22, 2011
VANMAN - That's great. I had the same problem. I would never have guessed you can simply prize the case appart unless you had pointed it out and just as you said one of the brushes had stuck. That's save me some money and hassle. Fan is back together now and working fine. Thanks again.
