Opinions on solar kit please
Dec 2, 2009
125
Hi All,
We've seriously been considering installing a solar panel to charge
the leisure battery, & I came across this company in the C&CC
magazine. I particularly like the look of the kit below:
http://selectatech.co.uk/shop/90w-solar-panel-roof-kit/
At £199 for a 90W kit, I thought that it looked a pretty good buy.
I plan to install it on the roof close to the offside, then run the
cable forward down through the awning channel & under the caravan.
there is already a waterproof grommet used to get the motor mover cables
to behind the battery box, & I plan to use this to get entry for
the solar cables.
Does what I plan sound sensible?
Thanks for any feedback,
Jim
2,399
Hi Jim
The price is reasonable for a 90W panel with everything you need to mount it on the roof of your caravan.
Before you go ahead contact the supplier to find out if the panel has monocrystalline solar cells. These are the most efficient and you should expect them rather than polycrystalline for the price, but there is no information in the description. The other thing to ask is if there is a built in blocking diode (I'm sure that there will be) to stop the battery from discharging during the hours of darkness.
I roof mounted my solar panel but used the cable gland for the cable to enter above the wardrobe, I then hid the cable behind the lockers and connected to the charge controller.
A couple of tips:
Mount the charge controller on a couple of small wooden batons or similar to provide an air gap underneath (2-3cm) rather than surface to surface because it can get warm.
If your caravan was built by Swift you can connect from the controller directly into the charging circuit by using a Sargent Solar Connector (£3.29)
Place the mounting brackets on the roof and mark the position where they will go with a pancil or marker pen.
Use some masking tape round the edges of the markings and lightly score the mounting surface with wet & dry or similar.
Before applying the bonding agent thoroughly clean the roof where the brackets will go with white spirit, and then use methylated spirit to get rid of the oily residue left by the white spirit.
Good Luck and if you have any questions get in touch
Dec 2, 2009
125
Hi Parksy,
Many thanks for the feedback & the tips. I did some more digging on the suppliers website, & yes, there is a blocking diode. I also found the following:
Our 90w panels are monocrystalline with our 120w and 135w
polycrystalline. There is an argument that polycrystalline are the
better performing panel when it comes to low light conditions (cloudier
days) and they do ‘start up’ quicker than a monocrystalline. In the
instance of the size of panels and wattage, you wouldn’t notice the
difference. If you had a bank of 20, then yes but a single panel then it
is not going to make a great deal of difference (we are talking very
very small percentages of difference in efficiency).
Our caravan is a 2013 Lunar Clubman SE, so we don't have a direct connection in the wiring loom for a solar panel. Also, our dealer has told us that Lunar won't honour the water ingress warranty if we penetrate the roof to gain cable entry, even if we use a waterproof gland. This is why I plan to route the solar cable under the van via the offside awning channel & gain entry using the waterproof grommet used for the motor mover cables.
We're going to do some more research over the weekend, & probably order sometime next week. I'll update this thread with whatever i decide to do.
Cheers,
Jim
P.S. Just thought of another question - how long will it take the bonding agent to set, so that I can return the caravan to the storage compond? I have no problem leaving it outside the front of our house over a weekend, just didn't want to go beyond that though.....
2,399
I'm not sure but I think that Deli Dave used the awning channel to route his reversing camera cables. When I fixed my panel I used stainless steel nuts, bolts and anti vibration washers to bolt the panel to the frame first.
After abrading the painted roof surface to provide a key (don't rub the paint off, just scratch the shine off) and removing all traces of grease etc I pumped wiggly lines of sikaflex onto both mounting surfaces, the roof and the mounting bracket.
I then placed the panel on the lines that I'd marked previously, lifted it once to get a good spread of Sikaflex and finally pushed the surfaces together.
You are looking for a good splurge of Sikaflex to come out from the sides of the bracket, you can easily clean this excess off before it sets with white spirit.
The panel should be set within an hour, perhaps a bit longer on a cool day. Sikaflex will work best between 15º and 25º.
I left my caravan overnight on the drive and it was set firm the next morning.
Mar 11, 2009
56
Due to not being able to drill the roof when I installed my solar panel I run the cable in a trunking across the roof to the corner of the caravan and run a length of trunking beside the awning rail, this allowed the use of the awing channel without having to disturb the cable for any reason, thus not having to drill the roof because of invalidating the water ingress warranty.
Dec 2, 2009
125
Hi Peter,
Thanks for the idea regarding using cable trunking. I think that I'll go ahead & use the awning channel though, as the battery locker is on the offside & there's no chance of using an awning on that side of the caravan.
I pulled the trigger on ordering the kit yesterday, should arrive tomorrow. I won't get a chance to fit it this weekend, as we have to visit daughter to do some jobs on her house for her. It'll have to wait a week.....
Cheers,
Jim
Just fitted a panel on the roof at the weekend, drilled up through the wardrobe and used one of those entry glands, sealed the hole with sikaflex then stuck the entry gland on also with sikaflex , that stuff is amazing
data:image/jpeg;base64,/9j/4AAQSkZJRgABAQEAYABgAAD/4R6yRXhpZgAATU0AKgAAAAgADAEOAAIAAAAgAAAIqgEPAAIAAAAWAAAIygEQAAIAAAALAAAI4AESAAMAAAABAAEAAAExAAIAAAAMAAAI7AEyAAIAAAAUAAAI+AITAAMAAAABAAIALodpAAQAAAABAAAJDJybAAEAAABAAAAbeJyfAAEAAABAAAAbuMSlAAcAAAKyAAAb+OocAAcAAAgMAAAAngAAAAAc6gAAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAE9MWU1QVVMgRElHSVRBTCBDQU1FUkEgICAgICAgICAAT0xZTVBVUyBJTUFHSU5HIENPUlAuAEZFMTkwL1g3NTAAAFZlcnNpb24gMS4wADIwMTM6MDQ6MTcgMTc6NTM6NTgAACSCmgAFAAAAAQAAEs6CnQAFAAAAAQAAEtaIIgADAAAAAQAFAACIJwADAAAAAQBQAACQAAAHAAAABDAyMjGQAwACAAAAFAAAEt6QBAACAAAAFAAAEvKRAQAHAAAABAECAwCRAgAFAAAAAQAAEwaSBAAFAAAAAQAAEw6SBQAFAAAAAQAAExaSBwADAAAAAQAFAACSCAADAAAAAQAAAACSCQADAAAAAQAYAACSCgAFAAAAAQAAEx6SfAAHAAAHzAAAEyaShgAHAAAAfQAAGvKSkQACAAAAAzAwAACSkgACAAAAAzAwAACgAAAHAAAABDAxMDCgAQADAAAAAQABAACgAgAEAAAAAQAACwCgAwAEAAAAAQAACECjAAAHAAAAAQMAAACjAQAHAAAAAQEAAACkAQADAAAAAQAAAACkAgADAAAAAQAAAACkAwADAAAAAQAAAACkBAAFAAAAAQAAG3CkBgADAAAAAQAAAACkBwADAAAAAQAAAACkCAADAAAAAQAAAACkCQADAAAAAQAAAACkCgADAAAAAQAAAADqHAAHAAAIDAAACsLqHQAJAAAAAQAADcYAAAAAHOoAAAAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKAAAGQAAAAB8AAAAKMjAxMzowNDoxNyAxNzo1Mzo1OAAyMDEzOjA0OjE3IDE3OjUzOjU4AAAAAAIAAAABAAAAAAAAAAoAAAFGAAAAZAAAAD8AAAAKT0xZTVAAAQAZAAACBAADAAAACggAAAECAwABAAAAAQAAAAICAwABAAAAAAAAAAMCAwABAAAAAAAAAAQCBQABAAAAFggAAAUCBQABAAAAHggAAAYCCAAGAAAAJggAAAcCAgAIAAAAMggAAAgCAgA0AAAAOggAAAkCBwAgAAAAdggAAAADAwABAAAAAAAAAAEDAwABAAAAAAAAAAIDAwABAAAAAAAAAAMDAwABAAAAAAAAAAQDAwABAAAAAAAAAAYDAwABAAAAAAAAAAAPBwDoBQAAlggAAAAEAwABAAAAAQAAAAEEAwABAAAAAgAAAAIEBAABAAAACVAAAQMEAwABAAAAAgAAAAQEAgAMAAAAfg4AAAUEAgAKAAAAig4AACUCAgADAAAAMDQAAAoCBAACAAAAlA4AAAAAAAAAAAAAAAAAAAAAAABkAAAAZAAAAPobAADoAwAAqP/h/nz+pf/a/nT+RDQzMjcAAABbcGljdHVyZUluZm9dIFJlc29sdXRpb249MjFbQ2FtZXJhIEluZm9dIFR5cGU9U1g4NzYAAAAAAAAAAABPTFlNUFVTIERJR0lUQUwgQ0FNRVJBAP///////////wAAAAAAAAAAAAAAAAAAMDAAAAAAAAAAABlhEjEAAAwSAAAnmAAAC4QAABcIAAAXCAAAAAAAABfQAGQAvQBQHyAAAAAAAAAAAAAAAAAAAAAAJygOAwAAAAAAAAAAAAAAABsmAAA8ABFRAAAAAAAAAAAAAAAAAGQLhAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABEREREBBAO0A+wBAAIAAmcBQwIAAQJgWgABA1IAEAAYABAAGAAQACsAAAAAAAAAAAAAAAAAAQAAAL0BZQINArUDXQAAAT8CAAI2AAAQSBC8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIiIAQAD9QAAAAAJFgAAA+kAAAAAAAGGoAAAAAMAAAAAAAAAAAAAAAAEFARFBEUD7dAAA/UAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAM3w1NDOYLtgAAAAAAAAAAIQYh1yBzHDIAAAAAAAAAAHd3d3cApAEwAKIBLnQASy4AAGQAS1kAAAHuAUACpgFnAmcBQyAAAAkAAAAAAADFEgAAAAAAuQE7AIwA4QEEAVQMAAEEACAACgCxAS4AsQE9ALEBPQAbZAAOAgMAAAAAAH0OAAALEAhFAzgIlQAoAAAAAAAAAAAAAJmZr9sAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABgMAAAAAAADQ4Oz0AAAAAK/bAAP//////////wD//////////////wzfDU0M5gu2AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
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
yx3CplKz0Kimlc2LrXJXkZYVG1hkisyW7uJ4+ZSWU4UD0qDc5O7IVe9OzapHiMN6kk1DbHfTUkht5JF8x2wgPX1qRp7d1CRsx92PNUpr2RYwqZ8vpwaXystuXILc+9TKL6jT00JL2WRSJGkyqkYPpU8cTMRKgAVhgkVAoKsUmUFSO9W0uEiiMOQQBke1ZyvayHFJ6spLDh9ksmUU1fjCQnhQVIyOKzJn2THeTlj+Yq4rgoEdsDHBqpJtXYouxduSt9CockD1qS0jtLcAp8xxznuaqQzpGPmYMD3IxmldxhWiHzDqKwab93oW5Wd0Wrm5CkbCQfSqjznay9xyKiuJTGmMjc/B9RSxvGwRgwyfl/H6VUY2RMpOTuPtbxg6nJLDjB5+taEt6jqQqkMDx3rPVDDMXGMMDmkMowfQ9PahxUnoF3FWYwTSlpCzkDP506F0Yvlfl7YPeoS+QxboemKSOVQuWT5Se561pa5CsRh1BkGSec0yWQmEsUOV5pHMQUlF47VXeZVJXJrVRuK9ieK+Koko6kYPHSia8MvzIgA6ZzVVVaKHcCGO7IqaCW4WLy4kLM+Vz/Oq5VuG5oWesGKF7a3UZI+aQDmq7X7uQu7d+lUiI4PM2O25TjBHWnx3TPhgIsgc8daXIugNu1maMF/uRgzBvSrFvOqKScfMc9ayRcKF3jj1AqxbyJKgR1UY796hwsJSNSCRkvN85G3Gc9asrfxwzIMBkbOQOM/Wsl447fG1iwPrVWa4KtwQKIrsW52VjUv9Vm2tEW4zlT6VjxZkuxhjk85p8kokXBbnvUdqCIHeViSDhfTFWtib8zLk8j7/ADDt44JLZqukcTSlmiyR07ZpbedMlXCnIxlzxVeSeS4fYhCY6Y4zSUWO/UvG48pWZoTgqRnrz2NVbAkQuHgUljhSw5p0cu1mXzM46iniRpGVY0yepx6e9LZWDmKj2tx/aAhQDd1rQu47RXQiIuyjqDxmluruVEAt4du7jcB+YqG4mEEKoQSWHU8YNPWVik0tkJNqM0iYAwBwAKlN3I9sIVGBnJ9/aqcSLHGSCCXXk1NaxlmA80AE9x0FDiuglJ3u2PWEB9wYhQuPxokimWF324x1z1NSu6biobp3pigvGyFxznOajmY7pssadLb3EaiSLlOcj2q/GIS25B8xbGCeg9aybPbDB5SZyx5bHGKla4KZijAz3NRJXeg1PlRYuJ5pJlT5tq9Ce9RzE/dJwOtQqAThWJ2H5j6UOwZShXkA4+tFrFOd92KlwWVznBA7GoBdOxEecAHFQ2zFmZO5qTaUDMn3iQBWlktDNttF2OdzJtk69MVKbqRcg7vp61VgVSpMh+dDnpU5dVQFj161k/ItNvqSF9xCOxYMR+BqUyRQkxbjjOTzyagYrKuV5wOBjFU0jmd/3jEDGTTiropza0ReFwn+tdQB2AqAzXDqzYwo9acZ0gXlVIPQmmXF0rQ7F249cVUYib6NkAuHydoJXrSPcIJcMMMf4vQVHG37plPJU55PWnyMixZKjd1Jx1rS1mZX0sXWv9tuYzN5iL0CjGDVWO/fJ2nGeuRmoLSPziflKg1clW0jt/KRQr4yGBBzRotBXbdypPqMsoMBy2T8oBx+lQrG5mVSQMjtUoKJucNzt4AHei3lIlYuowOcEVa02Bu+rLMqxBgUUKMCo5pVj+VHycdAKjmnZCChGMcd6hYEoVwCT68VMY9xuQ83S9CBnvWrp2pohCbCc9BmufIfPIT6GrmmGP7RiViBjqD3rS1kSnZ3O4iSS6UEMh46Z5FZ9/ZmLiQdexq1pN7ZROryjLAAfLU5lXU9TxbozxIOoXPNQpHYnFxVnqcbf2Msb+dGhB71qeGPG+oeH7lZoZOUbIVwGU/ga7G50aLyBI0SkdCMisG90PSZThoArHupzVxrJJxauiauGd+ZOzNy7+J+gXytLd+DtKe5Yf6xIihPvwa5658b6ldI0dmwtYj8pVMjP41i3FpaWRKxiTIOPmqt5/GxlUjPGRSbj9lGT5l8ciKdDcyt5uTnkE0tpF5UgwQIx1GetOkkPTGPao4GYqcnmlzNoi6uSXflyPvTJHtTVkQRjAYEdCaem5lOeFBzTpcCMLEo4PbrU36Bo9RvmyOm0DINIGUgLITT0ykecEH0pwPnDcygFepxzRexVl0HIjRkcEZ6H1qLaY5BISSx6+1O87aBgElepNEc5KtJsG0cZppyQ1YkjZCd6EkqOBUTy3okJ80kKeo4oMytFhn+Yc4FKrpwGyc8YFWqkl1E0pCLquqQY2XUnA6e9aNt4l1gMCLxgAPXJNZ25MY7DqajCruO1unaqdWTI5Etjo18favFtSNw3qSK0bf4i6uqbpGGfauKWUKcYGKmjkCkbRkjvT9o10Fyq+53I+KF5E4MkjfQGqOueNW8QWphlLkZBwfWuSlk3uGblvSh3KkYHOc1EpKVtNTSLcHdMtPHGuNynJpvkqT+7JBxxmqpnLMXYk1LHKRgsai7NXUTeiHmI5+d+aQxsp6jn3oO5W3nG3FI0pbhRgL0p3Lc0L9nMiBS5UZ/OlMPlDaDu7U158jK9AOlODOdpUZPU89aLtEKavoIqnH3ePemnzG4RSB9KmzmXf8ALwuSCaabuIghSB9anmCU0RmGRuCp4603CrwWByOlSfaY8YVgc/rSFg5yAoA5xVJvqUmrDYyfmwMj3p4ZSOO1O8tMBQcZPPPWkeJY8jOPxpcyYlJp6jDhQSBziovNLKVwS3bHanOxYYQZxTVCxr23Hue9MTndgDIqnuT0z2pWnkPyYBFNVSUy7kU3ypT/AB4H1p6AmNmkQxkEcj0rKOMkmtO5QxxBc89etZp5PuKuIpBGNx6Y+hro4JPIigA6qM1z0SkniugdNsiRtyQvPtU1CsOveuZSMsW0nJbHJpsk7MSR0p8qrgLuUt6+lVWK9MduooRzN6ilwGJIUjvTPOKnBPToaaJSvCnt6U1XG7BzTSEWPMIPKk09pATuXv2qtvOdpI4pWGCMenpRYCfeVy2c57UsSh5CG4z8w9KaApTcxJ29aWJg3TqORzSYFlsKAw4IpSokcuRyOmKjDZTBHNNjk+Y4bketRYq6FaXCmM9jmoPOy7LtIytJIfMmzuAOMUyRSsiZJyTgn1rRRsSTf6tFZicv0ANQM8iSsu0Enr3qwfnZkK8jgDvVbbJFL5m08etCAcrJuLMufQelPRlLZJ/MUxSJW8wKACw4FNmURygAYI607ASxnL5bIHQH1qLIO7Bxj171IGOVySQ3TPanhE8ojcEAPJxkmlsA2J98TLnn606ArEDI7Et2qONY4FLgszE8elOUBBuIO7qB/jQIkklDfMTyefpU1ttYAZAz1Jqsr70bcPxqON3L8HaP6UWBdyeSRYpyse7b6+tTW7LIxwxBPXNVJox/rIpQ4xyCORWhZ2zJCJiwGegK0naw0rktsYo3KMCCOMA0SzfvG2ljj1p5towVfb97oQarS5ViuOOvBqLKTHewPcFlIMYBPrQoTaWkDLxn6mqcjsDjHtmp4/McFonDbV5BNXy2JRYtThTviG085qd5shdpBI9arrHNLEPlxjrxTogCjAkkDk5rKUbu5abWhM/zKcg5/nUG871bbwO5HGaWCXHCcAHuaW8bgjOD1H0pcrTsFyWVUeJGeLgHselDbdn3lAU8c1Gkk0kBWUENjr2xVISE/Ie9NQYSl2Lryyrh/lKjsaminGdwGBmq0haVCpADL047VLZtuHkjgKeSR29alx0FdkrQtcttQANnucVDEsiqehKvmnyTrHL1Zxn+LjNO82B0LpgZPTuKVmkFyeOYSSbXH0HemTOoHyIc96qRmRrgNgnaKsFtr8cbhn8aXJZlXutRJgd/ygDIyKrZwrA5OD0qZtzAIzYIB3GqqiQM0YbrzWsYksZGSpLOQqs2AM0rx/wlR3wfWopFZ3VFOQOakncnYFUjnAwK0sTdCh0WMorMSB3p0F15NuIkXLt1bHNQ+U6Bg6gHtU5D5QxyqG24PGMUmkwuyrPuEZZ4++Qe5oRI5I8KArjkYPFSXFpO1v5z5Kg8n3pLBJ2YLHHu9RjjFV0uA6C6jFq9vIvz5yG9KltZIywRl5HfHAqnJE8U5UJjk8elXIXkDL5kftgUnHqhbmhI5QgYJC/w9s1SuJDvY7EywyOOn0rRjmZ4woh+fPpWdPDK0mSucVnFdyrlQSh5V80kAnDYq68qIwWDIA/vDJNQLE6yHyxuyMdKlFtdtJ/qmwBwQuatxuEbrYfDA0n7ySLgdyMZqKG2dJMsAoYeuRVoxtGhOyTPuMfpVcROsm8I5JHUA4pWZXXYjnifcTDg56gd6SAkEiSPBbBwD1FXYIJME+Wwx0BFUvJuHlY7GLKfTtTSb0Fa+tieB3jLGQ8g4HtUV6sjFWZtwIxyasTwSrGG8piRz0qe1tjLkyoeB+RqbNe9YfK3okU7Nd0OyQcglc+gqRUVeNwAUZxVx7OSPyyoJG45X0qrJBdNKwWAufQCpSbdx2eyRE7q8fmKefT2qS1VWBGckc8Us2lXaMNkEjbhyQhxVmy0fVQ4T7Hcup6BYz/hQ4aaAoSvsQwsvnfNyFPAPSq9243K0LHg8/StZNC1eRyyaVdsAMACFv8ACmzeFvEMykR6LesD/ct3z+gpRjZlOE2tjOS4ZMr5hPPTNJ5r78Eg5Parv/CI+KG4Tw3qZyeq2chP8qvweBvFgRnbwvrHzDqtlJ/8TVOFtSfZz6pmII445A2OGIO73qabBkVQe4OcVtP4A8aPGAvhDWSR6WEv/wATVpfh546d1C+D9bwowSbCXn/x2os9ylCe1jngedhx+FMkbHyA8d66c/Dbx9Icp4K1vIP/AED5f/iaJPhj8Q3BZfBet8jH/HhJ/wDE0lAbpzfRnLIZFDMjdfu0yWZhCGI6nkV2SfCz4jG2AXwVre7rn7FIP6VRPwl+JjxtjwTrjDtmxkB/lVxim9ROnUeyZzLyCVMjHHAqujlkKHIHrXYL8I/iaYBG3gLWQTyT9jkz/KnP8HviXhBD4B1xezZtH/wrRJbE8k+z+44+C38/IWUIFGWLHApLt1iIRTkAfxDqa69/g18VDgL4E1nBPT7K3+FEvwT+KrbT/wAILq/4W5p211YvZz/lZx6PLLGQM5PQ0+SRdqhzgqOcetd3Z/BT4pDYJfA+qFVyQPJxUrfBD4nXiO1x4H1NSo+U+Vgn8qWlylSnbZ/ccHbXVuJApAX0cUupX8aM0UK4JI3HH3q7aP4H/EwQlf8AhBNUVx6xdahPwJ+Kw+74I1FjjqyYotG4vZ1F0ZwAEjgcYPOO1JuZGImQsO//AOuu5/4UZ8Wwdh8Danx38sf41NH8C/ixu58E6kB6eWP8avTuL2c/5WedgRkkOWAHTBq3YoVl4JYV6FJ8CfiaoD/8IPqDF+oCAEVLD8DfifbnB8E6gwPUhBxU811oHsproznLe8liTDJF0x0qxpmqFpBZ+eRGzZYRjk/Wuhn+CnxL+7F4M1MY7ladZ/BX4owyjPhTUl5+8Ixn+dTFLqVyVFsmF0oWwY216Qo7OOa4m4vJg7iK44B55xmvWpfhj8RvsPkyeD79pQvDiMc/WuSuPgr8UGcuPB9/j2Qc0krPc0qKpNLRnFvdmb/XNuz1JPWqzBDJlz36V2g+CnxQyGPgzUCAf7lK3wU+JyP8vg3UCOn+rz/WhRV9GZ8k92mcZLCrINpIB6CnQ2yLlQCADzXYf8KZ+KHIPg7UB158upE+DnxKjQhvCGokk8/u6fK7WuCi1rys4uUk/JkADjIHWolDq/XIPUiu2k+DvxMGFHg+/wDXmOmL8IfiWmS3hDUQ3/XI0KNkDjN9Gce2WHA59Pamor/wgY6V1v8Awqb4kLknwhqQ5/54mmN8K/iPkH/hENSwP+mDU1FktST1RyVzI8akHrVVHkfKjOK664+FfxFYZPhLUz/27t/hU0Hwq8dpFhvCmpAsOT9nbp+VUoOKFrI4+FJHyFjZtvXAzVpI2K73JHHHNdPF8M/HCAibwvqgA6Kts/8AhUj/AA58YquW8M6gAcYX7O5/pSad9hxRxLyMrEKxJqRTI/II9K3Z/h54yPzJ4T1Jfrbvz+lJH4D8ZqCT4Z1BR3zbv/hVcjtexJhuqRqHYZY9OKdDJITtGfrW3ceCvFjAZ8PXwP8A1wb/AAqKPwZ4mgYeZpF5g/8ATFqOSTWwddDM/iHz9OhxRGpyS7nA7jvWpN4V15XX/iWXOCef3Rpkmhawo+TTZx2IKGp9nLohtpbmY6lueo9QOKWMncC/RecVebRdSjGWsrjP+6cVC2l6ltwbSXOf7po5Jdg5kiCa5VTxyfY1DG8znbg4ParaabehubR+Oh2mpY7S8UndbS7s8fL2o5Gug1JPdkJRwVTI9cU6CUoWyRintZ3m7cYnAPfbUMlnd7yTE3PTip5JPSxfMlqiGUPPJhWAB71BNEYyBuzx6VcFheu3MZH1FOliNqoZoi5I49BVJSXQz0erKCyPwuM/Spo2ctuDE/WoRDK/7zyTknJ4qwu6IhWRskc1XK+wXB7iZCWwR2BphubhxnBIFB3ZIRTz0zUfzKxDkYHpS5fITbHpqbp8oAU5/Gpo7hpG3YGaoyReZIGXpVlYJEQsMA49aXKkPmb0Hu+G69PSl88YCgfjVEiQMS3PpUiTNnjAI9qfKEWPuHymA3XtVE9+OauTIQo4Oe9VSCPXiqRo3cdDneq5PJroHiZmYhvmwBzXOx5Ei+ma6DzQRnd1xkkVFRG2Hd2zHm9QNuKgklzwOB7V7PH+zB47lJZ7vTo8+sxOPyBq3H+yn4okUGbXdOU+xc/+y07x7nP7OT/4c8HRC7ctyPerEgcEEYwPavfYP2SdRI/0jxPbqevyQsf54rTtv2T4lI83xScdwtv/APXp8yD2b8j5rxIH2ngfSniEsRtXpzX1Cn7J+isq+d4juj/uwqP61eg/ZW8JABZNZ1B/90IuaXMh+ztu0fLEW5iy7cDHNRxxukuHbBPbFfW0H7LfgBCHlu9Tc9/3yD/2Wr8X7NXw0jw0kV+5Hc3IH8loBw7yPj5dxzuqMKQeF6jFfaMP7PHwsiwW0qR88Hdct/TFXIvgV8KogFPh6Fsc/NPIf/ZqL+TFyR/mPiBVcSlihI6VK6FsYXGPT1r7mh+DnwrhxjwxYkg/xEn+Zq5F8MPhlBgR+GNK/GIGhvyDlj/MfCCW7NIHRT8w54ojsyc742OTjp1r76TwP8PYSDF4c0oH1+zKf6Vaj8N+B4TlND0tfpap/hRr2Dlh3/D/AIJ+fos5zjy7duuOFqVNKnmyXt5DkhR8pr9B003wpFgR6ZYrjsLZP8Kso2gQkCKCBMekYFGr6Dfs11Pzxj0PUTOsa6bM/JwQhNWj4W8QvKfJ0W8fI7Qsf6V+hK6hpigKp2npwKe2s6ePvSsfxo17fiK9Puz4Bb4f+MbiEeT4Z1Fhnotq55/Klg+FXxDnIVPCGsbSeT9kcf0r77bW9NXrk/U0h13TQduB69RTSkugXp+Z8Hx/Bf4lyEiHwdqhHbMBFaC/Av4qzRDy/CN0CeuUANfb/wDwkWn9QB79KY3inTU5IHp1o959h3p9n/XyPiWH9nX4tTOH/wCEWnB7kso/rW1a/s5/FZCAPD+B6NMo/rX2APFunEnATn3pD4xssfKqj8aTU32J56a6M+TD+zX8VJ8/8SaFTjobqP8Axpi/sq/FaX/lyslyepvE6fnX1s3jOyHzAJmm/wDCbWgAP7vOPwo5ZLsNzp/ynymP2SPifKPmGmJ9bsf0FT237IHxGUFZNR0hQewnY/8AslfUbePLUDrGKgb4g2oAIdKajPuDqU+kfzPnS3/ZD8eqcnW9IT6SyHH/AI5VhP2OvF0gzJ4k0pTjnAkOf/Ha+gB8RbY5AlT8uaQ/Ea3zzMv0xS5Jb3D2sP5fzPCIP2NNdC/vvFdjn1WOT/Cra/sbakRiTxdbfT7MxH869s/4WNCBxOv4Cmf8LKh7TAkdsUvZyetx+1j0ivxPIE/Y0k2qs/jJeP7tof8A4qrUX7GdkpDN4vctt25FqMj6fNXqp+JCgECVvyqM/EggHa7j6DpRyPuHtlfSJ5tb/sa6UjBn8X3Tkelqv+NWh+xzoDHLeLL8Z9IEz/Ou6f4lMOA0n5VBP8V4bZglxcFC3Cg9aPZeYOt/dX3HHj9jPweSfN8S6oT1yEQZq0n
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
2,399
Nice Job Michael.
You may see that on mine the panel is sitting much higher away from the caravan roof. This is because it's mounted on an adjustable panel frame similar to This One so that I can tilt the panel up toward the sunlight
Thanks Parksy
I went for a 95 w panel as i know its not as efficient when flat hence the bigger panel.
I used 4 corner mounts ,2 longer ones and 2 smaller ones at the front direction of travel and tube of siksflex, one this was stuck down it wasnt going to move at all.
I cleaned the roof then primed it using Sika primer to make the sikaflex stick better.
One question i read that you must have the panel connected all the time unless you cover it as it is generating power, my battery was fully charged and the regulator went into charge regulation active,i.e. charging current reduced
Where does the unused power go?
2,399
Michael E said:
............One question i read that you must have the panel connected all the time unless you cover it as it is generating power, my battery was fully charged and the regulator went into charge regulation active,i.e. charging current reduced
That's a good question that I don't really know the correct answer to Michael
When the battery is fully charged the regulator uses blocking diodes to prevent more amperage from reaching the battery. The cables to the regulator from the panel are still powered up unless you have added a switch to the circuit.
Where does the power in a domestic 240v supply lighting circuit go when you turn off the light? Although the light is switched off you would still get a jolt if you touched the live wire, and a solar circuit could still short out if even if the battery was fully charged, which is why the instruction is to cover the panel. This applies mainly to ground level panels where there is a possibility of connecting cables accidentally touching and damaging the panel through a short circuit.
Dec 2, 2009
125
Well, I've done the deed & ordered the panel & kit. It arrived this morning. I have the cable clips & the stainless nuts/bolts/washers etc. so here's hoping for a dry day at the weekend.
My only concern is looking at the cable supplied......the outside sheath looks like it's 12mm diameter - I'm just hoping that this will fit in the awning channel.....
Cheers,
Jim
Dec 2, 2009
125
Just to update people........I installed the solar panel kit on Saturday. I had to route the cable internally & drill the roof, as as I suspected, the cable was just too thick to fit in the awning rail. I have an email from Lunar stating that the water ingress warranty will only be affected if there are problems caused by my work, which I think is fair enough.
Laying the cable & connecting to the battery all went very easily. Even drilling the roof wasn't too much trauma. The attachment of the panel to the roof isn't as neat as I would have liked, as a gust of wind caught the panel just as I was laying it on the areas of Sikaflex adhesive I had spread over where the corner brackets would lie. The brackets weren't perfectly aligned, so the Sikaflex smeared & is a bit messy, but as it's out of sight I'm not too upset. The important thing is that it's securely attached. Thinking about it now, it would have been much easier if I had asked a neighbour to help at that stage.
At the end of the day, I'm really pleased we went ahead & installed it, & I would definitely recommend Selectatech as a supplier. They answered all of my questions immediately & courteously, were very professional to deal with, & all kit arrived when promised & was as described.
Cheers,
Jim
