over charging
Jul 14, 2009
hi all im am very new to forums so please be easy on me ill start from the begining last night i went out side and heard the carbon monoxide detector in my caravan going for guns so i look and all my gas was off bottle disconected after further investigation i placed the detector in the battery box and it went bananas, the battery was hissing like a car battery does when charging ,the mains was connected and the power supply live so i disconnected everything took the battery out it seems fine when i put my multi meter on the van conections with the battery out it read that my charger /supply unit was pumping out 17volts i am asumming this is not normal i have a ranger pa8 power box under my van has anyone had such problems am i missing somthing any help will be great
david
44
19,185
'Power Ranger' you mean? like a 240 to 110v yellow transformer box except it's white and cooks batteries for fun!!
Exactly the same happened to me and it ruined my near brand new 110Ahr battery.
One word of advice..Bin it.. sadly the same might go for your battery but lets hope your luck changes and it's ok
Jul 14, 2009
sort of its a black box under the van gives supply to 12 volt suff plus keeps battery charged or thats what its ment to do what do you have now
Jul 15, 2008
3,751
848
Yes... and a cooking lead acid battery is dangerous.... all that hydrogen and the possibility of an electric spark.
I once witnessed such a battery explode on a truck when a loose terminal sparked on startup.....
sulphuric acid sprayed everywhere and the battery cover thrown 50ft vertically into the air.... you CM detector did you a favour.
Jul 14, 2009
yes i know i was lucky to catch it before anything major happened but what shall i do to fix this what power supply do you recomend should i just get a new one of what i got it was fairly old
Jan 20, 2009
56
i have now vented the battery through the floor
Hi,
Hydogen is lighter than air, venting a batterybox through the floor does no good, it needs high level venting. Petroleum vapours are heavier than air and they do vent through the floor.
geo
3,602
Does any one remember Greenwindows and their assertion that a gas heater was the cause of a carbon monoxide detector alert even though the heater was turned off?
I wonder if David's experience may be a possible answer to their question?
