Over run Damper
Nov 5, 2006
805
you should be just able to compress the damper by pushing it in with your knee, but it is very stiff. it should then return slowly to the extended position
Jul 31, 2010
1,285
When this happened to me, it turned out to be the brakes that needed adjusting. The brakes were not operating quick enough, so the damper was completely compressed before they operated at all, then as I pulled away the damper had to stretch to take up the slack. Ten minutes spent adjusting the brakes and everything went back to normal.
Steve W
