Patio gas
Jun 10, 2018
9
515
HNY everyone, I have a patio gas cylinder in my garage only 3 years old and it contains propane gas. Could i use it on the van.
Thankyou
Hobbyt600
BANNED
Sep 20, 2011
97
40
18,585
curly52
Calor “Patio Gas” cylinders have a 27mm outlet valve.
If your caravan has the historic type of UK gas system where a regulator is attached to the gas cylinder and a low-pressure flexible hose (with jubilee hose-clips) connects that regulator to the caravan’s metal gas pipework, then (as Anseo has advised) a 27mm clip-on regulator should be used (example here)
https://www.calor.co.uk/shop/essentials-patio-gas-clip-on-regulator.html
However, if your caravan has the more recent type of gas system where a 30mbar regulator is bulkhead-mounted and a high-pressure hose (‘pigtail’) connects that regulator to the gas cylinder, a UK butane-type pigtail (example here)
https://www.leisureshopdirect.com/g...opane-gas/pigtail-hose-for-butane-20inch-long
will be required together with a full-pressure 27mm clip-on adapter (example here)
https://www.caravanaccessoryshop.co.uk/product/propane-clip-on-adaptor-27mm/3324
Reactions: Anseo
